KERNEL_PY.kernel.studyedit.StudyEditor Class Reference
This class provides utility methods to complement Study and StudyBuilder classes. More...
def study (self)
def builder (self)
def lcc (self)
def findOrCreateComponent (self, moduleName, componentName=None, icon=None, containerName=_DEFAULT_CONTAINER)
 Find a component corresponding to the Salome module moduleName in the study. More...
def loadComponentEngine (self, sComponent, containerName=_DEFAULT_CONTAINER)
 Load the engine corresponding to sComponent in the container containerName, associate the engine with the component and load the CORBA objects of this component in the study. More...
def getOrLoadObject (self, item)
 Get the CORBA object associated with the SObject item, eventually by first loading it with the corresponding engine. More...
def findOrCreateItem (self, fatherItem, name, fileType=None, fileName=None, comment=None, icon=None, IOR=None, typeId=None)
 Find an object under fatherItem in the study with the given attributes. More...
def findItem (self, fatherItem, name=None, fileType=None, fileName=None, comment=None, icon=None, IOR=None, typeId=None)
 Find an item with given attributes under fatherItem in the study. More...
def createItem (self, fatherItem, name, fileType=None, fileName=None, comment=None, icon=None, IOR=None, typeId=None)
 Create a new object named name under fatherItem in the study, with the given attributes. More...
def setItem (self, item, name=None, fileType=None, fileName=None, comment=None, icon=None, IOR=None, typeId=None)
 Modify the attributes of an item in the study. More...
def removeItem (self, item, withChildren=False)
 Remove the given item from the study. More...
def setItemAtTag (self, fatherItem, tag, name=None, fileType=None, fileName=None, comment=None, icon=None, IOR=None, typeId=None)
 Find an item tagged tag under fatherItem in the study tree or create it if there is none, then set its attributes. More...
def getName (self, sObject)
 Return the name of the object sObject. More...
def setName (self, sObject, name)
 Set the name of the object sObject. More...
def getComment (self, sObject)
 Return the comment of the object sObject. More...
def setComment (self, sObject, comment)
 Set the comment of the object sObject. More...
def getAttributeValue (self, sObject, attributeName, default=None)
 Return the value of the attribute named attributeName on the object sObject, or default if the attribute doesn't exist. More...
def setAttributeValue (self, sObject, attributeName, attributeValue)
 Set the value of the attribute named attributeName on the object sObject to the value attributeValue. More...
def getTypeId (self, sObject)
 Return the value of the attribute "AttributeLocalID" of the object sObject, or None if it is not set. More...
def setTypeId (self, sObject, value)
 Set the attribute "AttributeLocalID" of the object sObject to the value value. More...
def getFileType (self, sObject)
 Return the value of the attribute "AttributeFileType" of the object sObject, or an empty string if it is not set. More...
def setFileType (self, sObject, value)
 Set the attribute "AttributeFileType" of the object sObject to the value value. More...
def getFileName (self, sObject)
 Return the value of the attribute "AttributeExternalFileDef" of the object sObject, or an empty string if it is not set. More...
def setFileName (self, sObject, value)
 Set the attribute "AttributeExternalFileDef" of the object sObject to the value value. More...
def getIcon (self, sObject)
 Return the value of the attribute "AttributePixMap" of the object sObject, or an empty string if it is not set. More...
def setIcon (self, sObject, value)
 Set the attribute "AttributePixMap" of the object sObject to the value value. More...
Those methods may be moved in those classes in the future. The preferred way to get a StudyEditor object is through the method getStudyEditor which allows to reuse existing instance or through the global module attribute EDITOR.
lccThis instance attribute provides access to the SALOME life cycle CORBA service.
studyThis instance attribute provides access to the Study object. It can be used to access the study but the attribute itself cannot be modified.
builderThis instance attribute provides access to the StudyBuilder object. It can be used to edit the study but the attribute itself cannot be modified.
This class provides utility methods to complement :class:`Study` and
:class:`StudyBuilder` classes. Those methods may be moved in those classes
in the future.
:meth:`getStudyEditor` which allows to reuse existing instances.
.. attribute:: lcc
   CORBA service.
.. attribute:: study
   This instance attribute provides access to the :class:`Study` object.
   be modified.
.. attribute:: builder
   This instance attribute provides access to the :class:`StudyBuilder`
   cannot be modified.
◆ builder()
◆ createItem()
def KERNEL_PY.kernel.studyedit.StudyEditor.createItem (   self,
  fatherItem,
  name,
  fileType = None,
  fileName = None,
  comment = None,
  icon = None,
  IOR = None,
  typeId = None
If an object named name already exists under the father object, the new object is created with a new name name_X where X is the first available index.
param fatherItem (SObject) item under which the new item will be added.
new SObject created in the study.
See setItem() for the description of the other parameters.
Create a new object named `name` under `fatherItem` in the study, with
the given attributes. If an object named `name` already exists under
the father object, the new object is created with a new name `name_X`
:type  fatherItem: SObject
:param fatherItem: item under which the new item will be added.
:return: new SObject created in the study
See :meth:`setItem` for the description of the other parameters.
References studyedit.StudyEditor.builder(), KERNEL_PY.kernel.studyedit.StudyEditor.builder(), studyedit.StudyEditor.setItem(), KERNEL_PY.kernel.studyedit.StudyEditor.setItem(), studyedit.StudyEditor.study(), and KERNEL_PY.kernel.studyedit.StudyEditor.study().
Referenced by studyedit.StudyEditor.findOrCreateItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.findOrCreateItem().
◆ findItem()
def KERNEL_PY.kernel.studyedit.StudyEditor.findItem (   self,
  fatherItem,
  name = None,
  fileType = None,
  fileName = None,
  comment = None,
  icon = None,
  IOR = None,
  typeId = None
If none is found, return None. If several items correspond to the parameters, only the first one is returned. The search is made only on given parameters (i.e. not None). To look explicitly for an empty attribute, use an empty string in the corresponding parameter.
See setItem() for the description of the parameters.
Find an item with given attributes under `fatherItem` in the study. If
none is found, return :const:`None`. If several items correspond to
only on given parameters (i.e. not :const:`None`). To look explicitly
parameter.
See :meth:`setItem` for the description of the parameters.
References studyedit.StudyEditor.getComment(), KERNEL_PY.kernel.studyedit.StudyEditor.getComment(), SALOME_PyNode.BigFileOnDiskBase.getFileName(), SALOME_PyNode.BigObjectOnDiskBase.getFileName(), studyedit.StudyEditor.getFileName(), KERNEL_PY.kernel.studyedit.StudyEditor.getFileName(), studyedit.StudyEditor.getFileType(), KERNEL_PY.kernel.studyedit.StudyEditor.getFileType(), studyedit.StudyEditor.getIcon(), KERNEL_PY.kernel.studyedit.StudyEditor.getIcon(), SALOME::ExternalServerHandler.getName(), Engines::ContainerScriptPerfLog.getName(), Engines::PyNodeBase.getName(), SALOME_ExternalServerHandler.getName(), SALOME_ContainerScriptPerfLog.getName(), SALOME_StudyEditor.getName(), SALOME_PyNode.PyNode_i.getName(), SALOME_PyNode.PyScriptNode_Abstract_i.getName(), KERNEL_PY.kernel.testdata.TestData.getName(), studyedit.StudyEditor.getName(), KERNEL_PY.kernel.studyedit.StudyEditor.getName(), studyedit.StudyEditor.getTypeId(), KERNEL_PY.kernel.studyedit.StudyEditor.getTypeId(), studyedit.StudyEditor.study(), and KERNEL_PY.kernel.studyedit.StudyEditor.study().
◆ findOrCreateComponent()
def KERNEL_PY.kernel.studyedit.StudyEditor.findOrCreateComponent (   self,
  moduleName,
  componentName = None,
  icon = None,
  containerName = _DEFAULT_CONTAINER
If none is found, create a new component and associate it with the corresponding engine (i.e. the engine named moduleName). Note that in Salome 5, the module name and engine name must be identical (every module must provide an engine with the same name). In Salome 6 it will be possible to define a different name for the engine.
moduleName(string) name of the module corresponding to the component (the module name is the string value in the attribute "AttributeComment" of the component)
componentName(string) name of the new component if created. If None, use moduleName instead.
icon(string) icon for the new component (attribute "AttributePixMap").
containerName(string) name of the container in which the engine should be loaded.
the SComponent found or created.
Find a component corresponding to the Salome module `moduleName` in
the study. If none is found, create a new component and associate it
with the corresponding engine (i.e. the engine named `moduleName`).
engine.
:type  moduleName: string
:param moduleName: name of the module corresponding to the component
:type  componentName: string
:param componentName: name of the new component if created. If
                      :const:`None`, use `moduleName` instead.
:type  icon: string
:param icon: icon for the new component (attribute "AttributePixMap").
:type  containerName: string
:param containerName: name of the container in which the engine should be
                      loaded.
:return: the SComponent found or created.
References studyedit.StudyEditor.builder(), KERNEL_PY.kernel.studyedit.StudyEditor.builder(), studyedit.StudyEditor.lcc(), KERNEL_PY.kernel.studyedit.StudyEditor.lcc(), LifeCycleCORBA_SWIGTest.LifeCycleCORBA_SWIGTest.lcc, SALOME_StudyEditor.setIcon(), studyedit.StudyEditor.setIcon(), KERNEL_PY.kernel.studyedit.StudyEditor.setIcon(), KERNEL_PY.salome_ComponentGUI.SetName(), studyedit.StudyEditor.study(), and KERNEL_PY.kernel.studyedit.StudyEditor.study().
◆ findOrCreateItem()
def KERNEL_PY.kernel.studyedit.StudyEditor.findOrCreateItem (   self,
  fatherItem,
  name,
  fileType = None,
  fileName = None,
  comment = None,
  icon = None,
  IOR = None,
  typeId = None
Return the first one found if at least one exists, otherwise create a new one with the given attributes and return it.
Find an object under `fatherItem` in the study with the given
attributes. Return the first one found if at least one exists,
References studyedit.StudyEditor.createItem(), KERNEL_PY.kernel.studyedit.StudyEditor.createItem(), studyedit.StudyEditor.findItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.findItem().
◆ getAttributeValue()
def KERNEL_PY.kernel.studyedit.StudyEditor.getAttributeValue (   self,
  sObject,
  attributeName,
  default = None
Return the value of the attribute named `attributeName` on the object
`sObject`, or `default` if the attribute doesn't exist.
References studyedit.StudyEditor.builder(), and KERNEL_PY.kernel.studyedit.StudyEditor.builder().
Referenced by studyedit.StudyEditor.getFileName(), KERNEL_PY.kernel.studyedit.StudyEditor.getFileName(), studyedit.StudyEditor.getFileType(), KERNEL_PY.kernel.studyedit.StudyEditor.getFileType(), studyedit.StudyEditor.getTypeId(), and KERNEL_PY.kernel.studyedit.StudyEditor.getTypeId().
◆ getComment()
def KERNEL_PY.kernel.studyedit.StudyEditor.getComment (   self,
  sObject
Referenced by studyedit.StudyEditor.findItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.findItem().
◆ getFileName()
def KERNEL_PY.kernel.studyedit.StudyEditor.getFileName (   self,
  sObject
object `sObject`, or an empty string if it is not set.
References studyedit.StudyEditor.getAttributeValue(), and KERNEL_PY.kernel.studyedit.StudyEditor.getAttributeValue().
Referenced by SALOME_PyNode.BigObjectOnDiskSequence.__getitem__(), studyedit.StudyEditor.findItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.findItem().
◆ getFileType()
def KERNEL_PY.kernel.studyedit.StudyEditor.getFileType (   self,
  sObject
◆ getIcon()
def KERNEL_PY.kernel.studyedit.StudyEditor.getIcon (   self,
  sObject
◆ getName()
def KERNEL_PY.kernel.studyedit.StudyEditor.getName (   self,
  sObject
◆ getOrLoadObject()
def KERNEL_PY.kernel.studyedit.StudyEditor.getOrLoadObject (   self,
  item
Get the CORBA object associated with the SObject `item`, eventually by
References studyedit.StudyEditor.loadComponentEngine(), and KERNEL_PY.kernel.studyedit.StudyEditor.loadComponentEngine().
◆ getTypeId()
def KERNEL_PY.kernel.studyedit.StudyEditor.getTypeId (   self,
  sObject
`sObject`, or :const:`None` if it is not set.
◆ lcc()
◆ loadComponentEngine()
def KERNEL_PY.kernel.studyedit.StudyEditor.loadComponentEngine (   self,
  sComponent,
Load the engine corresponding to `sComponent` in the container
`containerName`, associate the engine with the component and load the
References studyedit.StudyEditor.builder(), KERNEL_PY.kernel.studyedit.StudyEditor.builder(), studyedit.StudyEditor.lcc(), KERNEL_PY.kernel.studyedit.StudyEditor.lcc(), and LifeCycleCORBA_SWIGTest.LifeCycleCORBA_SWIGTest.lcc.
Referenced by studyedit.StudyEditor.getOrLoadObject(), and KERNEL_PY.kernel.studyedit.StudyEditor.getOrLoadObject().
◆ removeItem()
def KERNEL_PY.kernel.studyedit.StudyEditor.removeItem (   self,
  item,
  withChildren = False
Note that the items are never really deleted. They just don't appear in the study anymore.
item(SObject) the item to be removed
withChildren(boolean) if True, also remove the children of item
True if the item was removed successfully, or False if an error happened.
Remove the given item from the study. Note that the items are never
:type  item: SObject
:param item: the item to be removed
:type  withChildren: boolean
:param withChildren: if :const:`True`, also remove the children of
                     `item`
:return: :const:`True` if the item was removed successfully, or
         :const:`False` if an error happened.
◆ setAttributeValue()
def KERNEL_PY.kernel.studyedit.StudyEditor.setAttributeValue (   self,
  sObject,
  attributeName,
  attributeValue
Set the value of the attribute named `attributeName` on the object
`sObject` to the value `attributeValue`.
Referenced by studyedit.StudyEditor.setFileName(), KERNEL_PY.kernel.studyedit.StudyEditor.setFileName(), studyedit.StudyEditor.setFileType(), KERNEL_PY.kernel.studyedit.StudyEditor.setFileType(), studyedit.StudyEditor.setTypeId(), and KERNEL_PY.kernel.studyedit.StudyEditor.setTypeId().
◆ setComment()
def KERNEL_PY.kernel.studyedit.StudyEditor.setComment (   self,
  sObject,
  comment
◆ setFileName()
def KERNEL_PY.kernel.studyedit.StudyEditor.setFileName (   self,
  sObject,
  value
Set the attribute "AttributeExternalFileDef" of the object `sObject`
to the value `value`.
References studyedit.StudyEditor.setAttributeValue(), and KERNEL_PY.kernel.studyedit.StudyEditor.setAttributeValue().
Referenced by studyedit.StudyEditor.setItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.setItem().
◆ setFileType()
def KERNEL_PY.kernel.studyedit.StudyEditor.setFileType (   self,
  sObject,
  value
Set the attribute "AttributeFileType" of the object `sObject` to the
value `value`.
◆ setIcon()
def KERNEL_PY.kernel.studyedit.StudyEditor.setIcon (   self,
  sObject,
  value
Set the attribute "AttributePixMap" of the object `sObject` to the
value `value`.
Referenced by studyedit.StudyEditor.findOrCreateComponent(), KERNEL_PY.kernel.studyedit.StudyEditor.findOrCreateComponent(), studyedit.StudyEditor.setItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.setItem().
◆ setItem()
def KERNEL_PY.kernel.studyedit.StudyEditor.setItem (   self,
  item,
  name = None,
  fileType = None,
  fileName = None,
  comment = None,
  icon = None,
  IOR = None,
  typeId = None
Unspecified attributes (i.e. those set to None) are left unchanged.
item(SObject) item to modify.
name(string or unicode) item name (attribute AttributeName).
fileType(string or unicode) item file type (attribute AttributeFileType).
fileName(string or unicode) item file name (attribute AttributeExternalFileDef).
comment(string or unicode) item comment (attribute AttributeComment). Note that this attribute will appear in the Value column in the object browser.
icon(string or unicode) item icon name (attribute AttributePixMap).
IOR(string) IOR of a CORBA object associated with the item (attribute AttributeIOR).
typeId(integer) item type (attribute AttributeLocalID).
Modify the attributes of an item in the study. Unspecified attributes
(i.e. those set to :const:`None`) are left unchanged.
:type  item: SObject
:param item: item to modify.
:type  name: string or unicode
:param name: item name (attribute 'AttributeName').
:type  fileType: string or unicode
:param fileType: item file type (attribute 'AttributeFileType').
:type  fileName: string or unicode
:param fileName: item file name (attribute
                 'AttributeExternalFileDef').
:type  comment: string or unicode
:param comment: item comment (attribute 'AttributeComment'). Note that
                this attribute will appear in the 'Value' column in
                the object browser.
:type  icon: string or unicode
:param icon: item icon name (attribute 'AttributePixMap').
:type  IOR: string
:param IOR: IOR of a CORBA object associated with the item
            (attribute 'AttributeIOR').
:type  typeId: integer
:param typeId: item type (attribute 'AttributeLocalID').
References studyedit.StudyEditor.builder(), KERNEL_PY.kernel.studyedit.StudyEditor.builder(), studyedit.StudyEditor.setComment(), KERNEL_PY.kernel.studyedit.StudyEditor.setComment(), SALOME_ContainerHelper.InOutputObjVisitorAbstract.setFileName(), SALOME_ContainerHelper.ObjMemModel.setFileName(), SALOME_ContainerHelper.FakeObjVisitor.setFileName(), studyedit.StudyEditor.setFileName(), KERNEL_PY.kernel.studyedit.StudyEditor.setFileName(), studyedit.StudyEditor.setFileType(), KERNEL_PY.kernel.studyedit.StudyEditor.setFileType(), SALOME_StudyEditor.setIcon(), studyedit.StudyEditor.setIcon(), KERNEL_PY.kernel.studyedit.StudyEditor.setIcon(), SALOME_ContainerScriptPerfLog.setName(), SALOMEDSImpl_GenericVariable.setName(), SALOME_StudyEditor.setName(), studyedit.StudyEditor.setName(), KERNEL_PY.kernel.studyedit.StudyEditor.setName(), KERNEL_PY.kernel.testdata.TestData.setName(), studyedit.StudyEditor.setTypeId(), and KERNEL_PY.kernel.studyedit.StudyEditor.setTypeId().
Referenced by studyedit.StudyEditor.createItem(), KERNEL_PY.kernel.studyedit.StudyEditor.createItem(), studyedit.StudyEditor.setItemAtTag(), and KERNEL_PY.kernel.studyedit.StudyEditor.setItemAtTag().
◆ setItemAtTag()
def KERNEL_PY.kernel.studyedit.StudyEditor.setItemAtTag (   self,
  fatherItem,
  tag,
  name = None,
  fileType = None,
  fileName = None,
  comment = None,
  icon = None,
  IOR = None,
  typeId = None
fatherItem(SObject) item under which the tagged item will be looked for and eventually created.
taginteger) tag of the item to look for.
the SObject at tag if found or created successfully, or None if an error happened.
Find an item tagged `tag` under `fatherItem` in the study tree or
:param fatherItem: item under which the tagged item will be looked for
:type  tag: integer
:param tag: tag of the item to look for.
:return: the SObject at `tag` if found or created successfully, or
         :const:`None` if an error happened.
References studyedit.StudyEditor.builder(), KERNEL_PY.kernel.studyedit.StudyEditor.builder(), studyedit.StudyEditor.setItem(), and KERNEL_PY.kernel.studyedit.StudyEditor.setItem().
◆ setName()
def KERNEL_PY.kernel.studyedit.StudyEditor.setName (   self,
  sObject,
  name
◆ setTypeId()
def KERNEL_PY.kernel.studyedit.StudyEditor.setTypeId (   self,
  sObject,
  value
Set the attribute "AttributeLocalID" of the object `sObject` to the
value `value`.
◆ study()
