Engines::PyNode Interface Reference
import"SALOME_PyNode.idl";
Inheritance diagram for Engines::PyNode:
pickledArgs execute (in string functionName, in pickledArgs inargs) raises (SALOME::SALOME_Exception)
 execute a python function defined in the node More...
Container getContainer ()
string getCode ()
string getName ()
void defineNewCustomVar (in string varName, in pickledArgs valueOfVar) raises (SALOME::SALOME_Exception)
 This method allows to define a new global var called varName. More...
void executeAnotherPieceOfCode (in string codeStr) raises (SALOME::SALOME_Exception)
 This method executes the python code in codeStr and can append/remove symboles in context to make them available or not for future call of execute on this. More...
void Register ()
void UnRegister ()
void Destroy ()
◆ defineNewCustomVar()
void Engines::PyNodeBase::defineNewCustomVar ( in string  varName,
This newly created var will be set to value valueOfVar.
◆ Destroy()
Use UnRegister() instead.
◆ execute()
pickledArgs Engines::PyNode::execute ( in string  functionName,
functionNamethe python function defined in the node to execute
inargsinput argument values (tuple,dict) provided as a python pickle
output argument values (tuple) as a python pickle
Referenced by KERNEL_PY.salome_pynode.SmartPyNode::__getattr__().
◆ executeAnotherPieceOfCode()
void Engines::PyNodeBase::executeAnotherPieceOfCode ( in string  codeStr)
[in]codeStr- the python code (without statement) to be executed, that can modify the context initialized at initialization.
◆ getCode()
string Engines::PyNodeBase::getCode ( )
◆ getContainer()
◆ getName()
string Engines::PyNodeBase::getName ( )
◆ Register()
◆ UnRegister()
