23#ifndef _SALOME_PACOExtension_IDL_
24#define _SALOME_PACOExtension_IDL_
67 in
string provides_port_name,
interfaces that permits to add a dynamic port model to the SALOME object model.
interfaces for EngineComponent and Container
Interface of the Container.
Definition: SALOME_Component.idl:81
Interface of the component.
Definition: SALOME_Component.idl:328
Definition: SALOME_PACOExtension.idl:39
void updateInstanceNumber()
void create_paco_component_node_instance(in string registeredName, in string proxy_containerName)
Definition: SALOME_PACOExtension.idl:35
void send_parallel_proxy_object(in Object proxy_ref)
Interface of a Parallel_DSC component.
Definition: SALOME_PACOExtension.idl:54
void set_paco_proxy(in Object ref, in string provides_port_name, in Ports::PortProperties port_prop)
This operation gives the proxy node of a paco++ port to all the nodes.
Interface of a Parallel_Salome_file This interface is used by parallel components and containers.
Definition: SALOME_PACOExtension.idl:77
void recvFiles_node()
This method is used by the parallel implementation of recvFiles.
void setFileNode(in string file_name, in long node_nbr)
Set a number of node for the file.
Engines::Container updateFile(in Engines::file new_file)
This method update the state of file for the Parallel_Salome_file.
long getFileNode(in string file_name)
Get the number of the node that actually managed the file.
Interface of a Salome_file managed This file is independent of a Salome module.
Definition: SALOME_Component.idl:650
Interface of the Superv_Component.
Definition: DSC_Engines.idl:348
Interface of a PortProperties.
Definition: SALOME_Ports.idl:87
A file managed by a Salome_file.
Definition: SALOME_Component.idl:614
