Engines::Salome_file Interface Reference
Interface of a Salome_file managed This file is independent of a Salome module. More...
import"SALOME_Component.idl";
Inheritance diagram for Engines::Salome_file:
void load (in string hdf5_file) raises (SALOME::SALOME_Exception)
 Load a Salome_file from a hdf5 file. More...
void save (in string hdf5_file) raises (SALOME::SALOME_Exception)
 Save a Salome_file into a hdf5_file. More...
void save_all (in string hdf5_file) raises (SALOME::SALOME_Exception)
void setLocalFile (in string comp_file_name) raises (SALOME::SALOME_Exception)
 Add a Local file to the Salome_file. More...
void setDistributedFile (in string comp_file_name) raises (SALOME::SALOME_Exception)
 Add a Distributed file to the Salome_file. More...
void connect (in Engines::Salome_file source_Salome_file) raises (SALOME::SALOME_Exception)
 Connect a Salome_file with another Salome_file. More...
void connectDistributedFile (in string file_name, in Engines::Salome_file source_Salome_file) raises (SALOME::SALOME_Exception)
 Connect the managed file file_name to a Salome_file. More...
void setDistributedSourceFile (in string file_name, in string source_file_name) raises (SALOME::SALOME_Exception)
 Connect the file_name with a Distributed file_name. More...
void recvFiles () raises (SALOME::SALOME_Exception)
 Get all the distributed files managed by the Salome_file and check all the local files. More...
void removeFile (in string file_name) raises (SALOME::SALOME_Exception)
 Remove a file of the Salome_file. More...
void removeFiles ()
 Remove all the files of the Salome_file. More...
Engines::files getFilesInfos ()
 Get the list of the files managed by the Salome_file. More...
Engines::file getFileInfos (in string file_name) raises (SALOME::SALOME_Exception)
 Get a file managed by the Salome_file. More...
Engines::SfState getSalome_fileState ()
 Return the state of the Salome_file. More...
void setContainer (in Engines::Container container)
 Set the container where files are. More...
long open (in string fileName)
 Open the file transfer. More...
long openW (in string fileName)
 Open the file transfer in write mode for file fileName. More...
void close (in long fileId)
 Close the file transfer. More...
fileBlock getBlock (in long fileId)
 Get a file data block. More...
void putBlock (in long fileId, in fileBlock block)
 Put a file data block. More...
void Register ()
void UnRegister ()
void Destroy ()
It can managed one or more real files. It's useful for parallel files. Currently Salome_file cannot manage two files that have the same name but not the same path.
◆ close()
void Engines::fileTransfer::close ( in long  fileId)
when the file transfer is finished, close method releases structures created by open method, identified by fileId.
◆ connect()
void Engines::Salome_file::connect ( in Engines::Salome_file  source_Salome_file)
It works only if the Salome_file managed only one file
source_Salome_fileSalome_file that managed the distributed version of the file.
Exceptions
raisedif there is more or less than one file.
◆ connectDistributedFile()
void Engines::Salome_file::connectDistributedFile ( in string  file_name,
file_namename of the file without the path.
Exceptions
raisedif the file doesn't exist.
◆ Destroy()
Use UnRegister() instead.
◆ getBlock()
fileBlock Engines::fileTransfer::getBlock ( in long  fileId)
Get successive blocks of octets from the original file. The last block is empty, and identifies the end of file.
◆ getFileInfos()
Engines::file Engines::Salome_file::getFileInfos ( in string  file_name)
file_namethe name of the file.
CORBA file reference.
Exceptions
◆ getFilesInfos()
Engines::files Engines::Salome_file::getFilesInfos ( )
The list can be empty.
◆ getSalome_fileState()
Engines::SfState Engines::Salome_file::getSalome_fileState ( )
◆ load()
void Engines::Salome_file::load ( in string  hdf5_file)
hdf5_filename (with path) of the hdf5_file.
Exceptions
containsinformation of errors if the loading doesn't succeed.
◆ open()
long Engines::fileTransfer::open ( in string  fileName)
open method returns a key (fileId) that identifies the structure (ex: C FILE), associated to the original file on the server. The structure is created by a container for transfer of files availables on the computer which runs the container. Each open gives a unique fileId, to allow concurrent reads of the same File.
◆ openW()
long Engines::fileTransfer::openW ( in string  fileName)
fileNamethe file to copy into with putBlock
the id to use with putBlock
◆ putBlock()
void Engines::fileTransfer::putBlock ( in long  fileId,
in fileBlock  block
fileIdidentification of the file obtained by openW
blocka data block to copy into the file identified by fileId
◆ recvFiles()
void Engines::Salome_file::recvFiles ( )
Exceptions
raisedif some of the files are not ok.
◆ Register()
◆ removeFile()
void Engines::Salome_file::removeFile ( in string  file_name)
file_namename of the file.
Exceptions
◆ removeFiles()
void Engines::Salome_file::removeFiles ( )
◆ save()
void Engines::Salome_file::save ( in string  hdf5_file)
Exceptions
containsinformation of errors if the save doesn't succeed.
◆ save_all()
void Engines::Salome_file::save_all ( in string  hdf5_file)
All files that are managed are saved into the hdf5_file
Exceptions
◆ setContainer()
void Engines::Salome_file::setContainer ( in Engines::Container  container)
containercontainer CORBA's reference.
◆ setDistributedFile()
void Engines::Salome_file::setDistributedFile ( in string  comp_file_name)
comp_file_namename of the file with the path.
Exceptions
raisedif the file is already added into the Salome_file.
◆ setDistributedSourceFile()
void Engines::Salome_file::setDistributedSourceFile ( in string  file_name,
source_file_nameIt's the name of the file managed by the distributed source Salome_file.
Exceptions
◆ setLocalFile()
void Engines::Salome_file::setLocalFile ( in string  comp_file_name)
Exceptions
◆ UnRegister()
