Engines::fileTransfer Interface Reference
Interface of fileTransfer. More...
import"SALOME_Component.idl";
Inheritance diagram for Engines::fileTransfer:
long open (in string fileName)
 Open the file transfer. More...
long openW (in string fileName)
 Open the file transfer in write mode for file fileName. More...
void close (in long fileId)
 Close the file transfer. More...
fileBlock getBlock (in long fileId)
 Get a file data block. More...
void putBlock (in long fileId, in fileBlock block)
 Put a file data block. More...
void Register ()
void UnRegister ()
void Destroy ()
The fileTransfer and fileRef interfaces provide a file transfer service between different computers.
◆ close()
void Engines::fileTransfer::close ( in long  fileId)
when the file transfer is finished, close method releases structures created by open method, identified by fileId.
◆ Destroy()
Use UnRegister() instead.
◆ getBlock()
fileBlock Engines::fileTransfer::getBlock ( in long  fileId)
Get successive blocks of octets from the original file. The last block is empty, and identifies the end of file.
◆ open()
long Engines::fileTransfer::open ( in string  fileName)
open method returns a key (fileId) that identifies the structure (ex: C FILE), associated to the original file on the server. The structure is created by a container for transfer of files availables on the computer which runs the container. Each open gives a unique fileId, to allow concurrent reads of the same File.
◆ openW()
long Engines::fileTransfer::openW ( in string  fileName)
fileNamethe file to copy into with putBlock
the id to use with putBlock
◆ putBlock()
void Engines::fileTransfer::putBlock ( in long  fileId,
in fileBlock  block
fileIdidentification of the file obtained by openW
blocka data block to copy into the file identified by fileId
◆ Register()
◆ UnRegister()
