Engines::fileRef Interface Reference
Interface of fileRef. More...
import"SALOME_Component.idl";
Container getContainer ()
boolean addRef (in string machine, in string fileName)
string getRef (in string machine)
Data Fields
readonly attribute string origFileName
 the original file More...
readonly attribute string refMachine
 the machine of the original file More...
The fileTransfer and fileRef interfaces provide a file transfer service between different computers.
A fileRef object is associated to an original file (origFileName) on a machine (refMachine). It is created by a container (factoryServer) on refMachine, with createFileRef(in string origFileName) method. The fileRef object maintains a list of (machine,filename) for copies. If a copy exists on myMachine, getRef(myMachine) returns the file name of the copy on myMachine, else returns empty string. If there is no copy on myMachine, method getFileTransfer() from container factoryServer on refMachine provides a fileTransfer object dedicated to CORBA file copy. After the copy, addRef(myMachine, localFileNameOnMyMachine) registers the file name of the copy on myMachine.
◆ addRef()
boolean Engines::fileRef::addRef ( in string  machine,
in string  fileName
◆ getContainer()
◆ getRef()
string Engines::fileRef::getRef ( in string  machine)
◆ origFileName
readonly attribute string Engines::fileRef::origFileName
the original file
◆ refMachine
readonly attribute string Engines::fileRef::refMachine
