SALOME_Parametric.idl File Reference
struct  SALOME_TYPES::Parameter
 Structure describing a parameter that can be used for specific information exchange between the codes. More...
struct  SALOME_TYPES::ParametricInput
 Structure describing the input of a computation code. More...
struct  SALOME_TYPES::ParametricOutput
 Structure describing the output of a computation code. More...
Modules
module  SALOME_TYPES
 This module contains type definitions for the communication between supervision codes and computation codes in parametric studies.
Typedefs
typedef sequence< Parameter > SALOME_TYPES::ParameterList
 List of parameters. More...
typedef sequence< double > SALOME_TYPES::Variable
 Type representing the value of a single variable exchanged between the codes (e.g. More...
typedef sequence< Variable > SALOME_TYPES::VariableSequence
 Type representing a state, i.e. More...
typedef sequence< VariableSequence > SALOME_TYPES::StateSequence
 Type representing a set of states. More...
typedef sequence< StateSequence > SALOME_TYPES::TimeSequence
 Type representing a time sequence, with a set of states for each time step. More...
typedef sequence< string > SALOME_TYPES::VarList
 List of variable names. More...
