SALOME_Parametric.idl
23// File : SALOME_Parametric.idl
24// Author : Renaud BARATE, EDF R&D
25//
26
27#ifndef _SALOME_Parametric_IDL_
28#define _SALOME_Parametric_IDL_
35{
39 struct Parameter {
40 string name;
41 string value;
42 };
43
46 typedef sequence<Parameter> ParameterList;
47
52 typedef sequence<double> Variable;
53
57 typedef sequence<Variable> VariableSequence;
58
61 typedef sequence<VariableSequence> StateSequence;
62
66 typedef sequence<StateSequence> TimeSequence;
67
70 typedef sequence<string> VarList;
71
79 };
80
88 };
89
90};
91
92#endif
This module contains type definitions for the communication between supervision codes and computation...
Definition: SALOME_Parametric.idl:35
sequence< VariableSequence > StateSequence
Type representing a set of states.
Definition: SALOME_Parametric.idl:61
sequence< Parameter > ParameterList
List of parameters.
Definition: SALOME_Parametric.idl:46
sequence< Variable > VariableSequence
Type representing a state, i.e.
Definition: SALOME_Parametric.idl:57
sequence< StateSequence > TimeSequence
Type representing a time sequence, with a set of states for each time step.
Definition: SALOME_Parametric.idl:66
sequence< double > Variable
Type representing the value of a single variable exchanged between the codes (e.g.
Definition: SALOME_Parametric.idl:52
sequence< string > VarList
List of variable names.
Definition: SALOME_Parametric.idl:70
Structure describing a parameter that can be used for specific information exchange between the codes...
Definition: SALOME_Parametric.idl:39
string value
Definition: SALOME_Parametric.idl:41
string name
Definition: SALOME_Parametric.idl:40
Structure describing the input of a computation code.
Definition: SALOME_Parametric.idl:74
VarList inputVarList
Definition: SALOME_Parametric.idl:75
TimeSequence inputValues
Definition: SALOME_Parametric.idl:77
ParameterList specificParameters
Definition: SALOME_Parametric.idl:78
VarList outputVarList
Definition: SALOME_Parametric.idl:76
Structure describing the output of a computation code.
Definition: SALOME_Parametric.idl:83
long returnCode
Definition: SALOME_Parametric.idl:86
TimeSequence outputValues
Definition: SALOME_Parametric.idl:84
ParameterList specificOutputInfos
Definition: SALOME_Parametric.idl:85
string errorMessage
Definition: SALOME_Parametric.idl:87
