SALOME_TYPES Module Reference
This module contains type definitions for the communication between supervision codes and computation codes in parametric studies. More...
struct  Parameter
 Structure describing a parameter that can be used for specific information exchange between the codes. More...
struct  ParametricInput
 Structure describing the input of a computation code. More...
struct  ParametricOutput
 Structure describing the output of a computation code. More...
Typedefs
typedef sequence< Parameter > ParameterList
 List of parameters. More...
typedef sequence< double > Variable
 Type representing the value of a single variable exchanged between the codes (e.g. More...
typedef sequence< Variable > VariableSequence
 Type representing a state, i.e. More...
typedef sequence< VariableSequence > StateSequence
 Type representing a set of states. More...
typedef sequence< StateSequence > TimeSequence
 Type representing a time sequence, with a set of states for each time step. More...
typedef sequence< string > VarList
 List of variable names. More...
typedef sequence< long > ListOfLong
typedef sequence< double > ListOfDouble
typedef sequence< string > ListOfString
typedef sequence< ListOfDouble > ListOfDouble2
Typedef Documentation
◆ ListOfDouble
typedef sequence<double> SALOME_TYPES::ListOfDouble
◆ ListOfDouble2
◆ ListOfLong
typedef sequence<long> SALOME_TYPES::ListOfLong
◆ ListOfString
typedef sequence<string> SALOME_TYPES::ListOfString
◆ ParameterList
List of parameters.
◆ StateSequence
◆ TimeSequence
Hence it is represented as a sequence of StateSequence.
◆ Variable
typedef sequence<double> SALOME_TYPES::Variable
a force "F"). As the variables may be vectors (or even matrices), their value is represented as a sequence of real numbers.
◆ VariableSequence
a set containing the values of all the variables of interest.
◆ VarList
typedef sequence<string> SALOME_TYPES::VarList
