SALOMEDS_Attributes.idl File Reference
This file contains a set of interfaces for the attributes which can be assigned to SObject. More...
import "SALOMEDS.idl";
Include dependency graph for SALOMEDS_Attributes.idl:
struct  SALOMEDS::Color
 Represents the color based on RGB palette. More...
interface  SALOMEDS::AttributeReal
 Attribute allowing to store a real value. More...
interface  SALOMEDS::AttributeInteger
 Attribute allowing to store an integer value. More...
interface  SALOMEDS::AttributeSequenceOfReal
 Attribute allowing to store a sequence of real values. More...
interface  SALOMEDS::AttributeSequenceOfInteger
 Attribute allowing to store a sequence of integer values. More...
interface  SALOMEDS::AttributeName
 Name attribute. More...
interface  SALOMEDS::AttributeComment
 Comment attribute. More...
interface  SALOMEDS::AttributeString
 String attribute. More...
interface  SALOMEDS::AttributeIOR
 IOR attribute. More...
interface  SALOMEDS::AttributePersistentRef
 Persistent reference attribute. More...
interface  SALOMEDS::AttributeExternalFileDef
 External file definition. More...
interface  SALOMEDS::AttributeFileType
 External file type definition. More...
interface  SALOMEDS::AttributeDrawable
 Drawable flag attribute. More...
interface  SALOMEDS::AttributeSelectable
 Selectable flag attribute. More...
interface  SALOMEDS::AttributeExpandable
 Expandable flag attribute. More...
interface  SALOMEDS::AttributeFlags
 Flags attribute. More...
interface  SALOMEDS::AttributeGraphic
 Graphic attribute. More...
interface  SALOMEDS::AttributeOpened
 Opened flag Attribute. More...
interface  SALOMEDS::AttributeTextColor
 Text color attribute. More...
interface  SALOMEDS::AttributeTextHighlightColor
 Text highlight color attribute. More...
interface  SALOMEDS::AttributePixMap
 Icon attribute. More...
interface  SALOMEDS::AttributeTreeNode
 Tree node attribute. More...
interface  SALOMEDS::AttributeLocalID
 Local identifier attribute. More...
interface  SALOMEDS::AttributeUserID
 Attribute storing GUID. More...
interface  SALOMEDS::AttributeTarget
 Back references attribute. More...
interface  SALOMEDS::AttributeTable
 Generic table attribute. More...
exception  SALOMEDS::AttributeTable::IncorrectIndex
 This exception is raised when an invalid (out of range) index is passed as parameter. More...
exception  SALOMEDS::AttributeTable::IncorrectArgumentLength
 This exception is raised when sequence of incorrect length is passed as parameter. More...
interface  SALOMEDS::AttributeTableOfInteger
 Table of integer values. More...
interface  SALOMEDS::AttributeTableOfReal
 Table of real values. More...
interface  SALOMEDS::AttributeTableOfString
 Table of string values. More...
interface  SALOMEDS::AttributeStudyProperties
 Study properties attribute More...
interface  SALOMEDS::AttributePythonObject
 Python object attribute. More...
interface  SALOMEDS::AttributeParameter
 Parameter attribute. More...
exception  SALOMEDS::AttributeParameter::InvalidIdentifier
 This exception is raised when an invalid identifier is passed as parameter. More...
Modules
namespace  SALOMEDS
 This package contains the interfaces used for creation, management and modification of the Study.
Typedefs
typedef sequence< double > SALOMEDS::DoubleSeq
 Sequence of double values. More...
typedef sequence< long > SALOMEDS::LongSeq
 Sequence of long values. More...
typedef sequence< string > SALOMEDS::StringSeq
 Sequence of string values. More...
