SALOMEDS::AttributeTextHighlightColor Interface Reference
Text highlight color attribute. More...
Inheritance diagram for SALOMEDS::AttributeTextHighlightColor:
Color TextHighlightColor ()
 Returns the value of the attribute. More...
void SetTextHighlightColor (in Color value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute allows to specify the highlight color to be used to render the item in the Object browser (used only when the item is selected). If the attribute is not set for the SObject, default value (GUI specific) is used.
See example13 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeTextColor, AttributePixMap
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetTextHighlightColor()
void SALOMEDS::AttributeTextHighlightColor::SetTextHighlightColor ( in Color  value)
valuehighlight color value being set to the attribute
◆ TextHighlightColor()
Color SALOMEDS::AttributeTextHighlightColor::TextHighlightColor ( )
highlight color assigned to the attribute
◆ Type()
Get Type.
◆ UnRegister()
