SALOMEDS::AttributePixMap Interface Reference
Icon attribute. More...
Inheritance diagram for SALOMEDS::AttributePixMap:
boolean HasPixMap ()
 Checks if the pixmap is assigned to the attribute. More...
string GetPixMap ()
 Returns the value of the attribute. More...
void SetPixMap (in string value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Icon attribute.
This attribute is used to specify the name (file name) of an icon which should be drawn in the Object browser when rendering an item.
See example14 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeTextColor, AttributeTextHighlightColor
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetPixMap()
string SALOMEDS::AttributePixMap::GetPixMap ( )
icon file name assigned to the attribute (empty string if not set)
◆ GetSObject()
Get SObject.
◆ HasPixMap()
boolean SALOMEDS::AttributePixMap::HasPixMap ( )
true if an icon file name is set to the attribute
◆ Register()
◆ SetPixMap()
void SALOMEDS::AttributePixMap::SetPixMap ( in string  value)
icomfile name being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
