SALOMEDS::AttributeTextColor Interface Reference
Text color attribute. More...
Inheritance diagram for SALOMEDS::AttributeTextColor:
Color TextColor ()
 Returns the value of the attribute. More...
void SetTextColor (in Color value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute allows to specify the text color to be used to render the item in the Object browser. If the attribute is not set for the SObject, default value (GUI specific) is used.
See example12 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeTextHighlightColor, AttributePixMap
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetTextColor()
void SALOMEDS::AttributeTextColor::SetTextColor ( in Color  value)
valuetext color value being set to the attribute
◆ TextColor()
Color SALOMEDS::AttributeTextColor::TextColor ( )
text color assigned to the attribute
◆ Type()
Get Type.
◆ UnRegister()
