SALOMEDS::AttributeInteger Interface Reference
Attribute allowing to store an integer value. More...
Inheritance diagram for SALOMEDS::AttributeInteger:
long Value ()
 Returns the value of the attribute. More...
void SetValue (in long value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
See example17 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeReal, AttributeString
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeInteger::SetValue ( in long  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
long SALOMEDS::AttributeInteger::Value ( )
attribute value
