SALOMEDS::AttributeString Interface Reference
String attribute. More...
Inheritance diagram for SALOMEDS::AttributeString:
string Value ()
 Returns the value of the attribute. More...
void SetValue (in string value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
String attribute.
The attribute stores a string value containing arbitrary information.
See also
AttributeInteger, AttributeReal
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeString::SetValue ( in string  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
string SALOMEDS::AttributeString::Value ( )
attribute value
