SALOMEDS::AttributeReal Interface Reference
Attribute allowing to store a real value. More...
Inheritance diagram for SALOMEDS::AttributeReal:
double Value ()
 Returns the value of the attribute. More...
void SetValue (in double value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
See example1 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeInteger, AttributeString
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeReal::SetValue ( in double  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
double SALOMEDS::AttributeReal::Value ( )
attribute value
