SALOMEDS::AttributePersistentRef Interface Reference
Persistent reference attribute. More...
Inheritance diagram for SALOMEDS::AttributePersistentRef:
string Value ()
 Returns the value of the attribute. More...
void SetValue (in string value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
The attribute stores a persistent identifier of the object. It is a part of SALOME persistence mechanism .
See example7 for an example of this method usage in batchmode of SALOME application.
See also
AttributeIOR
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributePersistentRef::SetValue ( in string  value)
valueValue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
string SALOMEDS::AttributePersistentRef::Value ( )
attribute value
