SALOMEDS::AttributeIOR Interface Reference
IOR attribute. More...
Inheritance diagram for SALOMEDS::AttributeIOR:
string Value ()
 Returns the value of the attribute. More...
void SetValue (in string value)
 Sets the value of the attribute (IOR of a SObject). More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
IOR attribute.
The attribute stores a string value identifying a runtime object. In particular it contains CORBA Interoperable Object Reference.
See example19 for an example of this method usage in batchmode of SALOME application.
See also
AttributePersistentRef
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeIOR::SetValue ( in string  value)
valuevalue being set to the attribute.
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
string SALOMEDS::AttributeIOR::Value ( )
attribute value
