SALOMEDS::AttributeTreeNode Interface Reference
Tree node attribute. More...
Inheritance diagram for SALOMEDS::AttributeTreeNode:
void SetFather (in AttributeTreeNode father)
 Assigns the father tree node to this tree node. More...
boolean HasFather ()
 Checks if father tree node attribute is set for this tree node. More...
AttributeTreeNode GetFather ()
 Returns the father tree node of this tree node. More...
void SetPrevious (in AttributeTreeNode sibling)
 Assigns the previous sibling tree node to this tree node. More...
boolean HasPrevious ()
 Checks if previous sibling tree node attribute is set for this tree node. More...
AttributeTreeNode GetPrevious ()
 Returns the previous sibling tree node of this tree node. More...
void SetNext (in AttributeTreeNode sibling)
 Assigns the next sibling tree node to this tree node. More...
boolean HasNext ()
 Checks if next sibling tree node attribute is set for this tree node. More...
AttributeTreeNode GetNext ()
 Returns the next sibling tree node of this tree node. More...
void SetFirst (in AttributeTreeNode child)
 Sets the specified tree node as a first child of this tree node. More...
boolean HasFirst ()
 Checks if first child tree node attribute is set for this tree node. More...
AttributeTreeNode GetFirst ()
 Returns the first child tree node of this tree node. More...
void SetTreeID (in string ID)
 Sets identifier of the parent tree to this tree node. More...
string GetTreeID ()
 Returns identifier of the parent tree. More...
void Append (in AttributeTreeNode child)
 Appends specified tree node to the end of the children list of this tree node. More...
void Prepend (in AttributeTreeNode child)
 Puts specified tree node to the beginning of the children list of this tree node. More...
void InsertBefore (in AttributeTreeNode child)
 Insert specified tree node as a previous child in the parent tree node's children list. More...
void InsertAfter (in AttributeTreeNode child)
 Insert specified tree node as a next child in the parent tree node's children list. More...
void Remove ()
 Removes this tree node. More...
long Depth ()
 Returns the depth of the tree node in the tree structure. More...
boolean IsRoot ()
 Checks if the tree node is a root of the tree. More...
boolean IsDescendant (in AttributeTreeNode other)
 Checks if the tree node is a descendant of the specified tree node. More...
boolean IsFather (in AttributeTreeNode other)
 Checks if this tree node is a parent of the specified tree node other. More...
boolean IsChild (in AttributeTreeNode other)
 Checks if this tree node is a child of the specified tree node other. More...
string Label ()
 Returns string identifier of the owner SObject (e.g. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
By specifying the tree node attributes for the SObjects it is possible to create internal auxiliary object tree with its own structure and identifier.
Since each such tree is specified by the unique identifier, it is possible to create as many trees as required.
See example18 for an example of usage of this attribute in batchmode of SALOME application.
◆ Append()
void SALOMEDS::AttributeTreeNode::Append ( in AttributeTreeNode  child)
childtree node being added to the list of children
◆ CheckLocked()
Method CheckLocked.
◆ Depth()
long SALOMEDS::AttributeTreeNode::Depth ( )
The resulting value it equal to the number of the fathers of this tree node.
The depth of the root tree node is 0.
tree node's depth
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetFather()
AttributeTreeNode SALOMEDS::AttributeTreeNode::GetFather ( )
◆ GetFirst()
AttributeTreeNode SALOMEDS::AttributeTreeNode::GetFirst ( )
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetNext()
AttributeTreeNode SALOMEDS::AttributeTreeNode::GetNext ( )
◆ GetPrevious()
AttributeTreeNode SALOMEDS::AttributeTreeNode::GetPrevious ( )
◆ GetSObject()
Get SObject.
◆ GetTreeID()
string SALOMEDS::AttributeTreeNode::GetTreeID ( )
parent tree identifier
◆ HasFather()
boolean SALOMEDS::AttributeTreeNode::HasFather ( )
true if father tree node attribute is defined or false otherwise
◆ HasFirst()
boolean SALOMEDS::AttributeTreeNode::HasFirst ( )
true if first child tree node attribute is defined or false otherwise
◆ HasNext()
boolean SALOMEDS::AttributeTreeNode::HasNext ( )
true if next sibling tree node attribute is defined or false otherwise
◆ HasPrevious()
boolean SALOMEDS::AttributeTreeNode::HasPrevious ( )
true if previous sibling tree node attribute is defined or false otherwise
◆ InsertAfter()
void SALOMEDS::AttributeTreeNode::InsertAfter ( in AttributeTreeNode  child)
childtree node being inserted to the parent tree node
◆ InsertBefore()
void SALOMEDS::AttributeTreeNode::InsertBefore ( in AttributeTreeNode  child)
◆ IsChild()
boolean SALOMEDS::AttributeTreeNode::IsChild ( in AttributeTreeNode  other)
othertree node that is tested for being child of this tree node
true if this node is child of the other node or false otherwise
◆ IsDescendant()
boolean SALOMEDS::AttributeTreeNode::IsDescendant ( in AttributeTreeNode  other)
othertree node that is tested for being ancestor of this tree node
true if this node is descendant of the other node or false otherwise
◆ IsFather()
boolean SALOMEDS::AttributeTreeNode::IsFather ( in AttributeTreeNode  other)
othertree node that is tested for being father of this tree node
true if this node is father of the other node or false otherwise
◆ IsRoot()
boolean SALOMEDS::AttributeTreeNode::IsRoot ( )
true if it is a root tree node or false otherwise
◆ Label()
string SALOMEDS::AttributeTreeNode::Label ( )
"0:1:2").
string entry of the owner SObject
◆ Prepend()
void SALOMEDS::AttributeTreeNode::Prepend ( in AttributeTreeNode  child)
◆ Register()
◆ Remove()
void SALOMEDS::AttributeTreeNode::Remove ( )
◆ SetFather()
void SALOMEDS::AttributeTreeNode::SetFather ( in AttributeTreeNode  father)
fathertree node attribute being set as a parent of this tree node
◆ SetFirst()
void SALOMEDS::AttributeTreeNode::SetFirst ( in AttributeTreeNode  child)
childtree node attribute being set filrst child of this tree node
◆ SetNext()
void SALOMEDS::AttributeTreeNode::SetNext ( in AttributeTreeNode  sibling)
siblingtree node attribute being set as a next sibling of this tree node
◆ SetPrevious()
void SALOMEDS::AttributeTreeNode::SetPrevious ( in AttributeTreeNode  sibling)
siblingtree node attribute being set as a previous sibling of this tree node
◆ SetTreeID()
void SALOMEDS::AttributeTreeNode::SetTreeID ( in string  ID)
All tree nodes which belong to the same tree, should have the same identifier.
IDidentifier (arbitrary non-empty string) being set for this tree node
◆ Type()
Get Type.
◆ UnRegister()
