SALOMEDS::AttributePythonObject Interface Reference
Python object attribute. More...
Inheritance diagram for SALOMEDS::AttributePythonObject:
void SetObject (in string pyObject, in boolean isScript)
 Sets a Python object converted into a sequence of characters to the attribute. More...
string GetObject ()
 Returns a Python object stored in the attribute as a sequence of characters. More...
boolean IsScript ()
 Check if the value stored in the attribute is a Python script. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute is used to store python objects as a sequence of characters.
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetObject()
string SALOMEDS::AttributePythonObject::GetObject ( )
encoded Python object stored in the attribute (empty string if not set)
◆ GetSObject()
Get SObject.
◆ IsScript()
boolean SALOMEDS::AttributePythonObject::IsScript ( )
true if the sequence of characters stored in the attribute corresponds to a Python script or false otherwise
◆ Register()
◆ SetObject()
void SALOMEDS::AttributePythonObject::SetObject ( in string  pyObject,
in boolean  isScript
pyObjectsequence of characters representing the encoded Python object
isScriptif true, the pyObject parameter specifies a Python script
◆ Type()
Get Type.
◆ UnRegister()
