SALOMEDS::AttributeTable Interface Reference
Generic table attribute. More...
Inheritance diagram for SALOMEDS::AttributeTable:
exception  IncorrectArgumentLength
 This exception is raised when sequence of incorrect length is passed as parameter. More...
exception  IncorrectIndex
 This exception is raised when an invalid (out of range) index is passed as parameter. More...
enum  SortOrder { AscendingOrder , DescendingOrder }
 Sort order. More...
enum  SortPolicy {
  EmptyLowest , EmptyHighest , EmptyFirst , EmptyLast ,
  EmptyIgnore
 Sort policy (specifies how empty cells are taken into account when sorting) More...
void SetTitle (in string title)
 Sets the main title of the table. More...
string GetTitle ()
 Returns the title of the table. More...
void SetRowTitle (in long row, in string title) raises (IncorrectIndex)
 Sets the title of a row with specified index. More...
string GetRowTitle (in long row) raises (IncorrectIndex)
 Returns the title of a row with specified index. More...
void SetRowTitles (in StringSeq titles) raises (IncorrectArgumentLength)
 Sets the titles for all rows in the table. More...
StringSeq GetRowTitles ()
 Returns the titles of all rows of the table. More...
void SetColumnTitle (in long column, in string title) raises (IncorrectIndex)
 Sets the title of a column with specified index. More...
string GetColumnTitle (in long column) raises (IncorrectIndex)
 Returns the title of a column with specified index. More...
void SetColumnTitles (in StringSeq titles) raises (IncorrectArgumentLength)
 Sets the titles for all columns in the table. More...
StringSeq GetColumnTitles ()
 Returns the titles of all columns of the table. More...
void SetRowUnit (in long row, in string unit) raises (IncorrectIndex)
 Assigns the unit label to the row with specified index. More...
string GetRowUnit (in long row) raises (IncorrectIndex)
 Returns the unit label of a row with specified index. More...
void SetRowUnits (in StringSeq units) raises (IncorrectArgumentLength)
 Sets the unit labels for all rows in the table. More...
StringSeq GetRowUnits ()
 Returns the unit labels of all rows of the table. More...
long GetNbRows ()
 Returns the number of rows of the table. More...
long GetNbColumns ()
 Returns the number of columns of the table. More...
boolean HasValue (in long row, in long column)
 Check if the value is set for the cell with specified row and column indices. More...
void RemoveValue (in long row, in long column) raises (IncorrectIndex)
 Clear value in the specified table cell. More...
void SetNbColumns (in long columns)
 Sets the maximum number of columns in the table. More...
LongSeq GetRowSetIndices (in long row) raises (IncorrectIndex)
 Returns the indices of the columns in the specified row for which values are set. More...
LongSeq SortRow (in long row, in SortOrder order, in SortPolicy policy) raises (IncorrectIndex)
 Sort values in the specified table row. More...
LongSeq SortColumn (in long column, in SortOrder order, in SortPolicy policy) raises (IncorrectIndex)
 Sort values in the specified table column. More...
LongSeq SortByRow (in long row, in SortOrder order, in SortPolicy policy) raises (IncorrectIndex)
 Sort table columns by the specified row. More...
LongSeq SortByColumn (in long column, in SortOrder order, in SortPolicy policy) raises (IncorrectIndex)
 Sort table rows by the specified column. More...
void SwapCells (in long row1, in long column1, in long row2, in long column2) raises (IncorrectIndex)
 Swap values in two table cells. More...
void SwapRows (in long row1, in long row2) raises (IncorrectIndex)
 Swap two table rows. More...
void SwapColumns (in long column1, in long column2) raises (IncorrectIndex)
 Swap two table columns. More...
boolean ReadFromFile (in SALOMEDS::TMPFile fileStream)
 Reads a table from a byte stream. More...
SALOMEDS::TMPFile SaveToFile ()
 Saves a table into a byte stream. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Used as base interface for the AttributeTableOfInteger, AttributeTableOfReal and AttributeTableOfString. Provides functions which are common for all table attributes.
The indices of rows and columns in the table start from 1.
See also
AttributeTableOfInteger, AttributeTableOfReal, AttributeTableOfString
◆ SortOrder
Sort order.
AscendingOrder
The items are sorted ascending.
DescendingOrder
The items are sorted descending.
◆ SortPolicy
EmptyLowest
Empty cells are considered as lowest values.
EmptyHighest
Empty cells are considered as highest values.
EmptyFirst
Empty cells are always first.
EmptyLast
Empty cells are always last.
EmptyIgnore
Empty cells are ignored (stay at initial positions)
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetColumnTitle()
string SALOMEDS::AttributeTable::GetColumnTitle ( in long  column)
Raises an exception if column is out of range.
columncolumn index
column title (empty string if not set)
See also
SetColumnTitle()
◆ GetColumnTitles()
StringSeq SALOMEDS::AttributeTable::GetColumnTitles ( )
list of all columns titles
See also
SetColumnTitles()
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetNbColumns()
long SALOMEDS::AttributeTable::GetNbColumns ( )
columns count
See also
GetNbRows(), SetNbColumns()
◆ GetNbRows()
long SALOMEDS::AttributeTable::GetNbRows ( )
rows count
See also
GetNbColumns()
◆ GetRowSetIndices()
LongSeq SALOMEDS::AttributeTable::GetRowSetIndices ( in long  row)
Raises an exception if row is out of range.
rowrow index
list of column indices
◆ GetRowTitle()
string SALOMEDS::AttributeTable::GetRowTitle ( in long  row)
rowrow index
row title (empty string if not set)
See also
SetRowTitle()
◆ GetRowTitles()
StringSeq SALOMEDS::AttributeTable::GetRowTitles ( )
list of all rows titles
See also
SetRowTitles()
◆ GetRowUnit()
string SALOMEDS::AttributeTable::GetRowUnit ( in long  row)
rowrow index
row unit label (empty string if not set)
See also
SetRowUnit()
◆ GetRowUnits()
StringSeq SALOMEDS::AttributeTable::GetRowUnits ( )
list of all rows unit labels
See also
SetRowUnits()
◆ GetSObject()
Get SObject.
◆ GetTitle()
string SALOMEDS::AttributeTable::GetTitle ( )
table title (empty string if not set)
See also
SetTitle()
◆ HasValue()
boolean SALOMEDS::AttributeTable::HasValue ( in long  row,
in long  column
rowrow index
columncolumn index
true if value is set for the specified cell or false otherwise (or if row/column index is/are out of range)
◆ ReadFromFile()
boolean SALOMEDS::AttributeTable::ReadFromFile ( in SALOMEDS::TMPFile  fileStream)
fileStreambyte stream
true if table is successfully read or false otherwise
See also
SaveToFile()
◆ Register()
◆ RemoveValue()
void SALOMEDS::AttributeTable::RemoveValue ( in long  row,
in long  column
Raises an exception if row or column is out of range.
rowrow index
columncolumn index
See also
HasValue()
◆ SaveToFile()
SALOMEDS::TMPFile SALOMEDS::AttributeTable::SaveToFile ( )
byte stream with table representation
See also
ReadFromFile()
◆ SetColumnTitle()
void SALOMEDS::AttributeTable::SetColumnTitle ( in long  column,
in string  title
columncolumn index
titletitle being set to the column
See also
GetColumnTitle()
◆ SetColumnTitles()
void SALOMEDS::AttributeTable::SetColumnTitles ( in StringSeq  titles)
Raises an exception if length of the titles parameter is not equal to the number of columns in the table.
titlestitles being set to the table columns
See also
GetColumnTitles()
◆ SetNbColumns()
void SALOMEDS::AttributeTable::SetNbColumns ( in long  columns)
If new number of columns is less than the current one, the table is truncated (extra columns are removed).
It is recommended to set number of columns before assigning data to the table.
columnstotal number of columns being set for the table
See also
GetNbColumns()
◆ SetRowTitle()
void SALOMEDS::AttributeTable::SetRowTitle ( in long  row,
in string  title
rowrow index
titletitle being set to the row
See also
GetRowTitle()
◆ SetRowTitles()
void SALOMEDS::AttributeTable::SetRowTitles ( in StringSeq  titles)
Raises an exception if length of the titles parameter is not equal to the number of rows in the table.
titlestitles being set to the table rows
See also
GetRowTitles()
◆ SetRowUnit()
void SALOMEDS::AttributeTable::SetRowUnit ( in long  row,
in string  unit
rowrow index
unitunit label being set to the row
See also
GetRowUnit()
◆ SetRowUnits()
void SALOMEDS::AttributeTable::SetRowUnits ( in StringSeq  units)
Raises an exception if length of the units parameter is not equal to the number of rows in the table.
unitsunit labels being set to the table rows
See also
GetRowUnits()
◆ SetTitle()
void SALOMEDS::AttributeTable::SetTitle ( in string  title)
titletitle being set to the table
See also
GetTitle()
◆ SortByColumn()
LongSeq SALOMEDS::AttributeTable::SortByColumn ( in long  column,
in SortOrder  order,
All the table rows are sorted according to the values in the specified column. Sort order is specified by the order parameter. The policy specifies how to process empty cells (put to the first place, ignore, etc).
columncolumn index
ordersort order (ascending/descending)
policysort policy (specifies how to process empty cells)
list of mixed row indices
◆ SortByRow()
LongSeq SALOMEDS::AttributeTable::SortByRow ( in long  row,
in SortOrder  order,
All the table columns are sorted according to the values in the specified row. Sort order is specified by the order parameter. The policy specifies how to process empty cells (put to the first place, ignore, etc).
rowrow index
list of mixed column indices
◆ SortColumn()
LongSeq SALOMEDS::AttributeTable::SortColumn ( in long  column,
in SortOrder  order,
Other table columns are not affected.
columncolumn index
◆ SortRow()
LongSeq SALOMEDS::AttributeTable::SortRow ( in long  row,
in SortOrder  order,
Other table rows are not affected.
rowrow index
◆ SwapCells()
void SALOMEDS::AttributeTable::SwapCells ( in long  row1,
in long  column1,
in long  row2,
in long  column2
Raises an exception if any specified index is out of range.
row1first cell's row index
column1first cell's column index
row2second cell's row index
column2second cell's column index
◆ SwapColumns()
void SALOMEDS::AttributeTable::SwapColumns ( in long  column1,
in long  column2
Raises an exception if any column1 or column2 is out of range.
column1first column's index
column2second column's index
◆ SwapRows()
void SALOMEDS::AttributeTable::SwapRows ( in long  row1,
in long  row2
Raises an exception if any row1 or row2 is out of range.
row1first row's index
row2second row's index
◆ Type()
Get Type.
◆ UnRegister()
