SALOMEDS::AttributeSelectable Interface Reference
Selectable flag attribute. More...
Inheritance diagram for SALOMEDS::AttributeSelectable:
boolean IsSelectable ()
 Returns the value of the attribute. More...
void SetSelectable (in boolean value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This presentation attribute specifies if the parent SObject is selectable by the user in the Object browser. If this attribute is defined for the parent object and set to false, the item is not selectable in the Object browser. By default, the item is always selectable.
See example9 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeDrawable, AttributeExpandable
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ IsSelectable()
boolean SALOMEDS::AttributeSelectable::IsSelectable ( )
true if the item is selectable or false otherwise
◆ Register()
◆ SetSelectable()
void SALOMEDS::AttributeSelectable::SetSelectable ( in boolean  value)
valuevalue being set to the attribute (true if item should be selectable or false otherwise)
◆ Type()
Get Type.
◆ UnRegister()
