SALOMEDS::AttributeDrawable Interface Reference
Drawable flag attribute. More...
Inheritance diagram for SALOMEDS::AttributeDrawable:
boolean IsDrawable ()
 Returns the value of the attribute. More...
void SetDrawable (in boolean value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This presentation attribute specifies if the parent SObject should be displayed in the study tree in the Object browser.
If this attribute is defined for the parent object and set to false, the item is not displayed in the Object browser. By default, the item is always displayed.
See example8 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeExpandable, AttributeSelectable
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ IsDrawable()
boolean SALOMEDS::AttributeDrawable::IsDrawable ( )
true if the item is drawable or false otherwise
◆ Register()
◆ SetDrawable()
void SALOMEDS::AttributeDrawable::SetDrawable ( in boolean  value)
valuevalue being set to the attribute (true if item should be drawable or false otherwise)
◆ Type()
Get Type.
◆ UnRegister()
