SALOMEDS::AttributeGraphic Interface Reference
Graphic attribute. More...
Inheritance diagram for SALOMEDS::AttributeGraphic:
void SetVisibility (in long viewId, in boolean value)
 Set / clear visibility flag of the parent SObject for the view specified by viewId. More...
boolean GetVisibility (in long viewId)
 Get visibility flag of the parent SObject for the view specified by viewId. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Graphic attribute.
This interface is intended for storing information about graphical representation of the object in different views.
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ GetVisibility()
boolean SALOMEDS::AttributeGraphic::GetVisibility ( in long  viewId)
viewIdview identifier
visibility flag currently set to the attribute for the specified view
◆ Register()
◆ SetVisibility()
void SALOMEDS::AttributeGraphic::SetVisibility ( in long  viewId,
in boolean  value
valuevisibility flag value being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
