SALOMEDS::AttributeFlags Interface Reference
Flags attribute. More...
Inheritance diagram for SALOMEDS::AttributeFlags:
long GetFlags ()
 Returns the value of the attribute. More...
void SetFlags (in long flags)
 Sets the value of the attribute. More...
boolean Get (in long flags)
 Test the value for the specified flag or set of flags. More...
void Set (in long flags, in boolean value)
 Set/clear specific flag or set of flags. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Flags attribute.
The interface is intended for storing different object attributes that have only two states: 0 (false) or 1 (true).
The interpretation of the flag values attribute is a matter of the user.
The total number of flags which can be stored in a single attribute is defined by the size of CORBA::Long data type.
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ Get()
boolean SALOMEDS::AttributeFlags::Get ( in long  flags)
flagsflag or set of flags being tested.
true if all bits corresponding to the flags are currently set or false otherwise
◆ GetClassType()
Get the class type.
◆ GetFlags()
long SALOMEDS::AttributeFlags::GetFlags ( )
set of flags currently set to the attribute
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ Set()
void SALOMEDS::AttributeFlags::Set ( in long  flags,
in boolean  value
flagsflag or set of flags being set / cleared
valuetrue if all bits corresponding to the flags should be set or false if flag(s) should be cleared
◆ SetFlags()
void SALOMEDS::AttributeFlags::SetFlags ( in long  flags)
flagsnew set of flags to be stored in the attribute
◆ Type()
Get Type.
◆ UnRegister()
