SALOMEDS::AttributeLocalID Interface Reference
Local identifier attribute. More...
Inheritance diagram for SALOMEDS::AttributeLocalID:
long Value ()
 Returns the value of the attribute. More...
void SetValue (in long value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute can be used for identification of the SObject (for example by type).
See example15 for an example of this atrtibute usage in batchmode of SALOME application.
See also
AttributeUserID
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeLocalID::SetValue ( in long  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
long SALOMEDS::AttributeLocalID::Value ( )
attribute value
