SALOMEDS::AttributeUserID Interface Reference
Attribute storing GUID. More...
Inheritance diagram for SALOMEDS::AttributeUserID:
string Value ()
 Returns the value of the attribute. More...
void SetValue (in string value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute can be used to store arbitrary GUID. Attribute allowing to store GUID. In contrast to any other attribute (e.g. AttributeLocalID), it is possible to define as many GUID attributes for the same SObject as it is required provided that they have different GUID values.
See also
AttributeLocalID
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeUserID::SetValue ( in string  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
string SALOMEDS::AttributeUserID::Value ( )
attribute value
