SALOMEDS::AttributeSequenceOfInteger Interface Reference
Attribute allowing to store a sequence of integer values. More...
Inheritance diagram for SALOMEDS::AttributeSequenceOfInteger:
void Assign (in LongSeq other)
 Initialization of the attribute with initial data. More...
LongSeq CorbaSequence ()
 Returns the sequence of values stored in the attribute. More...
void Add (in long value)
 Adds new value to the end of the sequence. More...
void Remove (in long index)
 Removes an value by the specified index from the sequence stored in the attribute. More...
void ChangeValue (in long index, in long value)
 Sets new value to the sequence by the specified index. More...
long Value (in short index)
 Returns a value in the sequence specified by its index. More...
long Length ()
 Returns the length of the sequence stored in the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
The indices in the sequence start from 1.
See example4 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeSequenceOfReal
◆ Add()
void SALOMEDS::AttributeSequenceOfInteger::Add ( in long  value)
valuevalue being added to the sequence
◆ Assign()
void SALOMEDS::AttributeSequenceOfInteger::Assign ( in LongSeq  other)
othersequence of values assigned to the attribute
◆ ChangeValue()
void SALOMEDS::AttributeSequenceOfInteger::ChangeValue ( in long  index,
in long  value
indexindex in the sequence
valuenew value being set to the sequence by specified index
◆ CheckLocked()
Method CheckLocked.
◆ CorbaSequence()
LongSeq SALOMEDS::AttributeSequenceOfInteger::CorbaSequence ( )
sequence of values
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Length()
long SALOMEDS::AttributeSequenceOfInteger::Length ( )
sequence length
◆ Register()
◆ Remove()
void SALOMEDS::AttributeSequenceOfInteger::Remove ( in long  index)
indexindex of the value in the sequence to be removed
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
long SALOMEDS::AttributeSequenceOfInteger::Value ( in short  index)
value specified by index
