SALOMEDS::AttributeName Interface Reference
Name attribute. More...
Inheritance diagram for SALOMEDS::AttributeName:
string Value ()
 Returns the value assigned to the attribute. More...
void SetValue (in string value)
 Sets the value of the attribute (name of a SObject). More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Name attribute.
The attribute stores a string value, which corresponds to the name of the SObject or to the name of corresponding object.
See example5 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeComment
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeName::SetValue ( in string  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
string SALOMEDS::AttributeName::Value ( )
attribute value
