SALOMEDS::AttributeComment Interface Reference
Comment attribute. More...
Inheritance diagram for SALOMEDS::AttributeComment:
string Value ()
 Returns the value of the attribute. More...
void SetValue (in string value)
 Sets the value of the attribute (description of a SObject). More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Comment attribute.
The attribute stores arbitrary string value containing supplementary information about the SObject. This is common-usage attribute that can be used for any purpose.
There is only one explicit limitation: for the SComponent object representing the root item of the SALOME component tree, the AttributeComment is used to store component data type value. This attribute is automatically set with NewComponent() function of StudyBuilder. Also, the value of this attribute is returned by the ComponentDataType() function of SComponent interface.
See example6 for an example of this attribute usage in batchmode of SALOME application.
See also
AttributeName
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ SetValue()
void SALOMEDS::AttributeComment::SetValue ( in string  value)
valuevalue being set to the attribute
◆ Type()
Get Type.
◆ UnRegister()
◆ Value()
string SALOMEDS::AttributeComment::Value ( )
attribute value
