SALOMEDS::AttributeTarget Interface Reference
Back references attribute. More...
Inheritance diagram for SALOMEDS::AttributeTarget:
void Add (in SObject refobj)
 Adds specified SObject to the list of SObjects which refer to the owner SObject. More...
SALOMEDS::Study::ListOfSObject Get ()
 Returns a list of SObjects which refer to the owner SObject. More...
void Remove (in SObject anObject)
 Removes specified SObject from the list of SObjects which refer to the owner SObject. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
This attribute is used to store back references to all the SObjects that refer to the owner SObject.
This attribute is used for inner purposes (in particular, for performance optimization).
◆ Add()
void SALOMEDS::AttributeTarget::Add ( in SObject  refobj)
refobjSObject being added to the list
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ Get()
SALOMEDS::Study::ListOfSObject SALOMEDS::AttributeTarget::Get ( )
list of SObject referencing to the owher SObject
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ Register()
◆ Remove()
void SALOMEDS::AttributeTarget::Remove ( in SObject  anObject)
refobjSObject being removed to the list
◆ Type()
Get Type.
◆ UnRegister()
