SALOMEDS::AttributeOpened Interface Reference
Opened flag Attribute. More...
Inheritance diagram for SALOMEDS::AttributeOpened:
boolean IsOpened ()
 Returns the value of the attribute. More...
void SetOpened (in boolean value)
 Sets the value of the attribute. More...
 Method CheckLocked. More...
string Type ()
 Get Type. More...
string GetClassType ()
 Get the class type. More...
SObject GetSObject ()
 Get SObject. More...
void Register ()
void UnRegister ()
void Destroy ()
Warning
Deprecated interface. Not used since version 3.0.
This presentation attribute specifies if the item corresponding to the parent SObject in the Object browser is currently opened (expanded) or no.
◆ CheckLocked()
Method CheckLocked.
◆ Destroy()
Use UnRegister() instead.
◆ GetClassType()
Get the class type.
◆ GetLocalImpl()
in long  thePID,
out boolean  isLocal
◆ GetSObject()
Get SObject.
◆ IsOpened()
boolean SALOMEDS::AttributeOpened::IsOpened ( )
\obsolete
true if the item is opened (expanded) in the Object browser or false otherwise
◆ Register()
◆ SetOpened()
void SALOMEDS::AttributeOpened::SetOpened ( in boolean  value)
\obsolete
valuevalue being set to the attribute (true if item should be opened (expanded) or false otherwise)
◆ Type()
Get Type.
◆ UnRegister()
