23#ifndef _SALOME_CONTAINERMANAGER_IDL_
24#define _SALOME_CONTAINERMANAGER_IDL_
interfaces for EngineComponent and Container
This file contains the objects defining the main exception used in SALOME application.
interfaces for SALOME Resources Manager service
Interface of the containerManager This interface is used for interaction with the unique instance of ...
Definition: SALOME_ContainerManager.idl:83
void SetCodeOnContainerStartUp(in string code)
Container GiveContainer(in ContainerParameters params)
GiveContainer - use mode parameter of ContainerParameters to configure how this method works Currentl...
void SetTimeOutToLaunchServerInSecond(in long timeInSecond)
long GetTimeOutToLaunchServerInSecond()
void SetBigObjOnDiskThreshold(in long thresholdInByte)
long GetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond()
KeyValDict GetOverrideEnvForContainers()
long GetDeltaTimeBetweenCPUMemMeasureInMilliSecond()
void SetOverrideEnvForContainers(in KeyValDict env)
void SetDeltaTimeBetweenCPUMemMeasureInMilliSecond(in long timeInMS)
void ShutdownContainers()
Shutdown all containers that have been launched by the container manager. This termination is soft....
void SetNumberOfRetry(in long nbRetry)
void ShutdownContainersNow()
Stronger version than ShutdownContainers. This method does not wait for completion of last CORBA invo...
string GetCodeOnContainerStartUp()
void SetDeltaTimeBetweenNSLookupAtLaunchTimeInMilliSecond(in long timeInMS)
void SetBigObjOnDiskDirectory(in string directory)
void SetDirectoryForReplayFiles(in string directory)
Interface of the Container.
Definition: SALOME_Component.idl:81
sequence< KeyValPairString > KeyValDict
Definition: SALOME_ContainerManager.idl:76
Type to describe required properties of a container.
Definition: SALOME_ContainerManager.idl:38
string workingdir
container working directory if given else automatic
Definition: SALOME_ContainerManager.idl:56
string mode
creation mode for GiveContainer if given else automatic
Definition: SALOME_ContainerManager.idl:53
boolean isMPI
if true start a MPI container
Definition: SALOME_ContainerManager.idl:62
string container_name
container name if given else automatic
Definition: SALOME_ContainerManager.idl:40
string parallelLib
PaCO specific information.
Definition: SALOME_ContainerManager.idl:64
ResourceParameters resource_params
Parameters to choose a resource.
Definition: SALOME_ContainerManager.idl:67
long nb_proc
Number of proc of a parallel container.
Definition: SALOME_ContainerManager.idl:60
Definition: SALOME_ContainerManager.idl:71
string val
Definition: SALOME_ContainerManager.idl:73
string key
Definition: SALOME_ContainerManager.idl:72
Type to describe required properties of a resource.
Definition: SALOME_ResourcesManager.idl:42
