20#ifndef __SALOME_LOGMANAGER_IDL__
21#define __SALOME_LOGMANAGER_IDL__
static std::ostream * out
Definition: DSC_interface.cxx:381
This file contains a set of interfaces used for communication between components.
This file contains the objects defining the main exception used in SALOME application.
Definition: SALOME_LogManager.idl:48
string getContainerEntryInNS()
ContainerScriptPerfLog addScript(in string name, in string code)
ListOfContainerScriptPerfLog listOfScripts()
Definition: SALOME_LogManager.idl:29
SALOME::vectorOfByte getObj()
void assign(in SALOME::vectorOfByte value)
void assignAndAppendFreestyle(in SALOME::vectorOfByte value)
Definition: SALOME_LogManager.idl:38
ContainerScriptExecPerfLog addExecutionSession()
ListOfContainerScriptExecPerfLog listOfExecs()
Definition: SALOME_LogManager.idl:59
void versionA_IsTheLatestValidVersion()
SALOME::vectorOfByte getAllStruct(in boolean clearMemory)
void setFileNamePairOfLogger(in string loggerFileNameA, in string loggerFileNameB)
ContainerPerfLog declareContainer(in string contInNS, in string logfile)
void putStructInFileAtomic(in boolean clearMemory, in string fileName)
string getLastVersionOfFileNameLogger()
ListOfContainerPerfLog listOfContainerLogs()
void versionB_IsTheLatestValidVersion()
void getFileNamePairOfLogger(out string loggerFileNameA, out string loggerFileNameB)
sequence< ContainerScriptPerfLog > ListOfContainerScriptPerfLog
Definition: SALOME_LogManager.idl:45
sequence< ContainerScriptExecPerfLog > ListOfContainerScriptExecPerfLog
Definition: SALOME_LogManager.idl:35
sequence< ContainerPerfLog > ListOfContainerPerfLog
Definition: SALOME_LogManager.idl:56
sequence< octet > vectorOfByte
Definition: SALOME_Comm.idl:44
string name
Definition: pythfilter.py:56
