ParallelDSC_i.hxx
20// File : ParallelDSC_i.hxx
21// Author : André RIBES (EDF)
22// Module : KERNEL
23//
24#ifndef _PARALLEL_DSC_COMPONENT_I_HXX_
25#define _PARALLEL_DSC_COMPONENT_I_HXX_
26
27#include <iostream>
28#include <map>
30#include "DSC_interface.hxx"
32
33#include "SALOME_PACOExtensionPaCO_Engines_Parallel_DSC_server.hxx"
34#include "SALOME_PortsPaCO.hxx"
35
37 public virtual Engines_Parallel_Component_i,
38 public virtual Engines::Parallel_DSC_serv,
39 public virtual Engines_DSC_interface
40{
41public:
42 Engines_ParallelDSC_i(CORBA::ORB_ptr orb,
43 char * ior,
44 int rank,
45 PortableServer::POA_ptr poa,
46 PortableServer::ObjectId * contId,
47 const char *instanceName,
48 const char *interfaceName,
49 bool notif = false);
50
51 virtual ~Engines_ParallelDSC_i();
52
53
57 virtual void add_provides_port(Ports::Port_ptr ref,
58 const char* provides_port_name,
59 Ports::PortProperties_ptr port_prop)
60 {
62 provides_port_name,
63 port_prop);
64 }
65
69 virtual void add_uses_port(const char* repository_id,
70 const char* uses_port_name,
71 Ports::PortProperties_ptr port_prop)
72 {
74 uses_port_name,
75 port_prop);
76 }
77
81 virtual Ports::Port_ptr get_provides_port(const char* provides_port_name,
82 const CORBA::Boolean connection_error)
83 {
84 return Engines_DSC_interface::get_provides_port(provides_port_name,
85 connection_error);
86 }
87
91 virtual Engines::DSC::uses_port * get_uses_port(const char* uses_port_name)
92 {
93 return Engines_DSC_interface::get_uses_port(uses_port_name);
94 }
95
99 virtual void connect_provides_port(const char* provides_port_name)
100 {
102 }
103
107 virtual void connect_uses_port(const char* uses_port_name,
108 Ports::Port_ptr provides_port_ref)
109 {
111 provides_port_ref);
112 }
113
117 virtual CORBA::Boolean is_connected(const char* port_name)
118 {
119 return Engines_DSC_interface::is_connected(port_name);
120 }
121
125 virtual void disconnect_provides_port(const char* provides_port_name,
126 const Engines::DSC::Message message)
127 {
129 message);
130 }
131
135 virtual void disconnect_uses_port(const char* uses_port_name,
136 Ports::Port_ptr provides_port_ref,
137 const Engines::DSC::Message message)
138 {
140 provides_port_ref,
141 message);
142 }
143
144 virtual Ports::PortProperties_ptr get_port_properties(const char* port_name)
145 {
147 }
148
157 virtual void set_paco_proxy(CORBA::Object_ptr ref,
158 const char* provides_port_name,
159 Ports::PortProperties_ptr port_prop);
160
169 virtual CORBA::Boolean add_parallel_provides_proxy_port(const CORBA::Object_ptr ref,
170 const char * provides_port_name,
171 Ports::PortProperties_ptr port_prop);
172
180 virtual CORBA::Boolean add_parallel_provides_proxy_wait(const char * provides_port_name);
181
190 virtual CORBA::Boolean add_parallel_provides_node_port(Ports::Port_PaCO_ptr ref,
191 const char* provides_port_name);
192
200 virtual const char * get_proxy(const char* provides_port_name);
201
202};
203
204#endif
This class implements the interface Engines::DSC.
Definition: DSC_interface.hxx:45
virtual Ports::PortProperties_ptr get_port_properties(const char *port_name)
Definition: DSC_interface.cxx:362
virtual CORBA::Boolean is_connected(const char *port_name)
Definition: DSC_interface.cxx:252
virtual void add_uses_port(const char *repository_id, const char *uses_port_name, Ports::PortProperties_ptr port_prop)
Definition: DSC_interface.cxx:79
virtual void connect_provides_port(const char *provides_port_name)
Definition: DSC_interface.cxx:180
virtual void connect_uses_port(const char *uses_port_name, Ports::Port_ptr provides_port_ref)
Definition: DSC_interface.cxx:203
virtual Engines::DSC::uses_port * get_uses_port(const char *uses_port_name)
Definition: DSC_interface.cxx:142
virtual Ports::Port_ptr get_provides_port(const char *provides_port_name, const CORBA::Boolean connection_error)
Definition: DSC_interface.cxx:109
virtual void add_provides_port(Ports::Port_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
Definition: DSC_interface.cxx:51
virtual void disconnect_provides_port(const char *provides_port_name, const Engines::DSC::Message message)
Definition: DSC_interface.cxx:271
virtual void disconnect_uses_port(const char *uses_port_name, Ports::Port_ptr provides_port_ref, const Engines::DSC::Message message)
Definition: DSC_interface.cxx:296
Definition: ParallelDSC_i.hxx:40
virtual CORBA::Boolean add_parallel_provides_proxy_wait(const char *provides_port_name)
This method by the nodes that do not add the proxy to wait is reference.
Definition: ParallelDSC_i.cxx:94
Definition: ParallelDSC_i.hxx:107
Definition: ParallelDSC_i.hxx:144
Definition: ParallelDSC_i.hxx:135
Definition: ParallelDSC_i.hxx:81
virtual const char * get_proxy(const char *provides_port_name)
Used to get the proxy of the parallel port.
Definition: ParallelDSC_i.cxx:70
Definition: ParallelDSC_i.hxx:57
Definition: ParallelDSC_i.hxx:99
Definition: ParallelDSC_i.cxx:50
Definition: ParallelDSC_i.hxx:91
Definition: ParallelDSC_i.hxx:125
Definition: ParallelDSC_i.hxx:69
virtual void set_paco_proxy(CORBA::Object_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
This method is used to register the proxy of the parallel port into all the nodes of the parallel com...
Definition: ParallelDSC_i.cxx:57
Definition: ParallelDSC_i.hxx:117
virtual CORBA::Boolean add_parallel_provides_node_port(Ports::Port_PaCO_ptr ref, const char *provides_port_name)
Permits to add a parallel node of a parallel provides port.
Definition: ParallelDSC_i.cxx:115
Engines_ParallelDSC_i(CORBA::ORB_ptr orb, char *ior, int rank, PortableServer::POA_ptr poa, PortableServer::ObjectId *contId, const char *instanceName, const char *interfaceName, bool notif=false)
Definition: ParallelDSC_i.cxx:26
virtual CORBA::Boolean add_parallel_provides_proxy_port(const CORBA::Object_ptr ref, const char *provides_port_name, Ports::PortProperties_ptr port_prop)
This method is used by the node that want to add the parallel proxy port.
Definition: ParallelDSC_i.cxx:80
Definition: SALOME_ParallelComponent_i.hxx:63
char * instanceName()
CORBA method: return name of the instance, unique in this Container.
Definition: SALOME_ParallelComponent_i.cxx:145
char * interfaceName()
CORBA method: return name of the component class.
Definition: SALOME_ParallelComponent_i.cxx:156
Message
This enumeration is used when the connection of a port (uses or provides) is changed.
Definition: DSC_Engines.idl:79
sequence< Ports::Port > uses_port
a uses port
Definition: DSC_Engines.idl:73
poa
Definition: SALOME_ContainerPy.py:377
orb
Definition: salome.py:122
