prepare_test Namespace Reference
class  TestEnvironment
Variables
string usage
 parser
 help
 action
 args = parser.parse_args()
 opts = opt.split('=', 1)
 envTest = TestEnvironment()
 ret = envTest.run(args.command)
Variable Documentation
◆ action
prepare_test.action
◆ args
prepare_test.args = parser.parse_args()
◆ envTest
prepare_test.envTest = TestEnvironment()
◆ help
prepare_test.help
◆ opts
prepare_test.opts = opt.split('=', 1)
◆ parser
prepare_test.parser
Initial value:
1= argparse.ArgumentParser(description=usage,
2 formatter_class=argparse.RawDescriptionHelpFormatter)
◆ ret
prepare_test.ret = envTest.run(args.command)
◆ usage
string prepare_test.usage
Initial value:
1= """
2This script prepares the test environment and runs a test script:
3 - clean and create test directory
4 - create a SALOME application
5 - launch salome
6 - launch the test script within SALOME environment
7 - kill salome
8
9 This script uses the following environment variables:
10 - ROOT_SALOME : directory which contains salome_context.cfg.
11 This variable is usually defined in salome_prerequisites.sh
12 - KERNEL_ROOT_DIR and YACS_ROOT_DIR : directories of modules installation
13 Those variables are usually defined in salome_modules.sh
14 Environment variables can be passed to the script using the -d option.
15"""
Referenced by Engines_Component_i.CpuUsed(), and Engines_Parallel_Component_i.CpuUsed().
