fileTransfer_i Class Reference
A class to manage file transfer in SALOME. More...
#include <SALOME_FileTransfer_i.hxx>
Inheritance diagram for fileTransfer_i:
 fileTransfer_i ()
 Default constructor,. More...
virtual ~fileTransfer_i ()
CORBA::Long open (const char *fileName)
 open the given file More...
void close (CORBA::Long fileId)
 close a file More...
Engines::fileBlock * getBlock (CORBA::Long fileId)
 get a data block from a file More...
CORBA::Long openW (const char *fileName)
 open the given file in write mode (for copy) More...
void putBlock (CORBA::Long fileId, const Engines::fileBlock &block)
 put a data block for copy into a file More...
virtual PortableServer::POA_ptr _default_POA ()
 Get default POA for the servant object. More...
virtual void Register ()
 Increment reference counter. More...
virtual void UnRegister ()
 Decrement reference counter. More...
virtual void Destroy ()
int _fileKey
std::map< int, FILE * > _fileAccess
int _ctr
PortableServer::POA_var myPOA
int myRefCounter
◆ fileTransfer_i()
fileTransfer_i::fileTransfer_i ( )
References _fileKey.
◆ ~fileTransfer_i()
fileTransfer_i::~fileTransfer_i ( )
◆ _default_POA()
PortableServer::POA_ptr SALOME::GenericObj_i::_default_POA ( )
reference to the default POA for the servant
Reimplemented in SALOMEDS_ChildIterator_i, SALOMEDS_GenericAttribute_i, SALOMEDS_SComponentIterator_i, SALOMEDS_SObject_i, SALOMEDS_UseCaseBuilder_i, and SALOMEDS_UseCaseIterator_i.
References SALOME::GenericObj_i::myPOA.
◆ close()
void fileTransfer_i::close ( CORBA::Long  fileId)
close a file
CORBA method: close the file associated to the fileId given at open.
fileIdgot in return from open method
References _fileAccess.
◆ Destroy()
void SALOME::GenericObj_i::Destroy ( )
Deprecated:
Use UnRegister() instead.
◆ getBlock()
Engines::fileBlock * fileTransfer_i::getBlock ( CORBA::Long  fileId)
CORBA method: get a block of data from the file associated to the fileId given at open.
an octet sequence. Last one is empty.
References _fileAccess, and FILEBLOCK_SIZE.
◆ open()
CORBA::Long fileTransfer_i::open ( const char *  fileName)
open the given file
CORBA method: try to open the file. If the file is readable, return a positive integer else return 0;
fileNamepath to the file to be transferred
fileId = positive integer > 0 if open OK.
References _ctr, _fileAccess, and _fileKey.
◆ openW()
CORBA::Long fileTransfer_i::openW ( const char *  fileName)
CORBA method: try to open the file. If the file is writable, return a positive integer else return 0;
◆ putBlock()
void fileTransfer_i::putBlock ( CORBA::Long  fileId,
const Engines::fileBlock &  block
CORBA method: put a block of data into the file associated to the fileId given at openW.
fileIdgot in return from openW method
blockan octet sequence to copy into opened file
References _fileAccess, and SALOME_utilities::SCRUTE().
◆ Register()
void SALOME::GenericObj_i::Register ( )
◆ UnRegister()
void SALOME::GenericObj_i::UnRegister ( )
◆ _ctr
int fileTransfer_i::_ctr
Referenced by open(), and openW().
◆ _fileAccess
std::map<int, FILE* > fileTransfer_i::_fileAccess
Referenced by close(), getBlock(), open(), openW(), and putBlock().
◆ _fileKey
int fileTransfer_i::_fileKey
Referenced by fileTransfer_i(), open(), and openW().
◆ myPOA
◆ myRefCounter
int SALOME::GenericObj_i::myRefCounter
