SALOME_FileTransfer_i.hxx
23// File : SALOME_FileTransfer_i.hxx
24// Author : Paul RASCLE, EDF
25// Module : SALOME
26// $Header$
27//
28#ifndef _SALOME_FILETRANSFER_I_HXX_
29#define _SALOME_FILETRANSFER_I_HXX_
30
31#include "SALOME_Container.hxx"
32
34
35#include <SALOMEconfig.h>
36#include CORBA_SERVER_HEADER(SALOME_Component)
37#include <map>
38#include <cstdio>
39
41 public virtual POA_Engines::fileTransfer,
42 public virtual PortableServer::ServantBase,
43 public virtual SALOME::GenericObj_i
44{
45public:
47 virtual ~fileTransfer_i();
48
49 CORBA::Long open(const char* fileName);
50
51 void close(CORBA::Long fileId);
52
53 Engines::fileBlock* getBlock(CORBA::Long fileId);
54 CORBA::Long openW(const char* fileName);
55 void putBlock(CORBA::Long fileId, const Engines::fileBlock& block);
56
57protected:
59 std::map<int, FILE* > _fileAccess;
60 int _ctr;
61};
62
63#endif
#define CONTAINER_EXPORT
Definition: SALOME_Container.hxx:37
Implementation of the base servant for SALOME objects with reference counter.
Definition: SALOME_GenericObj_i.hh:53
A class to manage file transfer in SALOME.
Definition: SALOME_FileTransfer_i.hxx:44
std::map< int, FILE * > _fileAccess
Definition: SALOME_FileTransfer_i.hxx:59
int _ctr
Definition: SALOME_FileTransfer_i.hxx:60
int _fileKey
Definition: SALOME_FileTransfer_i.hxx:58
sequence< octet > fileBlock
A block of binary data used for file transfer. The maximum size of the block is defined on server sid...
Definition: SALOME_Component.idl:565
