SALOMEDSTest_Embedded Class Reference
#include <SALOMEDSTest.hxx>
Inheritance diagram for SALOMEDSTest_Embedded:
virtual void setUp ()
 Set up the environment. More...
virtual void tearDown ()
void testAttributeComment ()
 Check all methods of SALOMEDS_AttributeComment Use code of SALOMEDS_AttributeComment.cxx. More...
void testAttributeDrawable ()
 Check all methods of SALOMEDS_AttributeDrawable Use code of SALOMEDS_AttributeDrawable.cxx. More...
void testAttributeExpandable ()
 Check all methods of SALOMEDS_AttributeExpandable Use code of SALOMEDS_AttributeExpandable.cxx. More...
void testAttributeExternalFileDef ()
 Check all methods of SALOMEDS_AttributeExternalFileDef Use code of SALOMEDS_AttributeExternalFileDef.cxx. More...
void testAttributeFileType ()
 Check all methods of SALOMEDS_AttributeFileType Use code of SALOMEDS_AttributeFileType.cxx. More...
void testAttributeFlags ()
 Check all methods of SALOMEDS_AttributeFlags Use code of SALOMEDS_AttributeFlags.cxx. More...
void testAttributeGraphic ()
 Check all methods of SALOMEDS_AttributeGraphic Use code of SALOMEDS_AttributeGraphic.cxx. More...
void testAttributeIOR ()
 Check all methods of SALOMEDS_AttributeIOR Use code of SALOMEDS_AttributeIOR.cxx. More...
void testAttributeInteger ()
 Check all methods of SALOMEDS_AttributeInteger Use code of SALOMEDS_AttributeInteger.cxx. More...
void testAttributeLocalID ()
 Check all methods of SALOMEDS_AttributeLocalID Use code of SALOMEDS_AttributeLocalID.cxx. More...
void testAttributeName ()
 Check all methods of SALOMEDS_AttributeName Use code of SALOMEDS_AttributeName.cxx. More...
void testAttributeOpened ()
 Check all methods of SALOMEDS_AttributeOpened Use code of SALOMEDS_AttributeOpened.cxx. More...
void testAttributeParameter ()
 Check all methods of SALOMEDS_AttributeParameter Use code of SALOMEDS_AttributeParameter.cxx. More...
void testAttributePersistentRef ()
 Check all methods of SALOMEDS_AttributePersistentRef Use code of SALOMEDS_AttributePersistentRef.cxx. More...
void testAttributePixMap ()
 Check all methods of SALOMEDS_AttributePixMap Use code of SALOMEDS_AttributePixMap.cxx. More...
void testAttributePythonObject ()
 Check all methods of SALOMEDS_AttributePythonObject Use code of SALOMEDS_AttributePythonObject.cxx. More...
void testAttributeReal ()
 Check all methods of SALOMEDS_AttributeReal Use code of SALOMEDS_AttributeReal.cxx. More...
void testAttributeSelectable ()
 Check all methods of SALOMEDS_AttributeSelectable Use code of SALOMEDS_AttributeSelectable.cxx. More...
void testAttributeSequenceOfInteger ()
 Check all methods of SALOMEDS_AttributeSequenceOfInteger Use code of SALOMEDS_AttributeSequenceOfInteger.cxx. More...
void testAttributeSequenceOfReal ()
 Check all methods of SALOMEDS_AttributeSequenceOfReal Use code of SALOMEDS_AttributeSequenceOfReal.cxx. More...
void testAttributeStudyProperties ()
 Check all methods of SALOMEDS_AttributeStudyProperties Use code of SALOMEDS_AttributeStudyProperties.cxx. More...
void testAttributeTableOfInteger ()
 Check all methods of SALOMEDS_AttributeTableOfInteger Use code of SALOMEDS_AttributeTableOfInteger.cxx. More...
void testAttributeTableOfReal ()
 Check all methods of SALOMEDS_AttributeTableOfReal Use code of SALOMEDS_AttributeTableOfReal.cxx. More...
void testAttributeTableOfString ()
 Check all methods of SALOMEDS_AttributeTableOfString Use code of SALOMEDS_AttributeTableOfString.cxx. More...
void testAttributeTarget ()
 Check all methods of SALOMEDS_AttributeTarget Use code of SALOMEDS_AttributeTarget.cxx. More...
void testAttributeTextColor ()
 Check all methods of SALOMEDS_AttributeTextColor Use code of SALOMEDS_AttributeTextColor.cxx. More...
void testAttributeTextHighlightColor ()
 Check all methods of SALOMEDS_AttributeTextHighlightColor Use code of SALOMEDS_AttributeTextHighlightColor.cxx. More...
void testAttributeTreeNode ()
void testAttributeUserID ()
 Check all methods of SALOMEDS_AttributeUserID Use code of SALOMEDS_AttributeUserID.cxx. More...
void testChildIterator ()
 Check all methods of SALOMEDS_ChildIterator Use code of SALOMEDS_ChildIterator.cxx. More...
void testSComponent ()
 Check all methods of SALOMEDS_SComponent Use code of SALOMEDS_SComponent.cxx. More...
void testSComponentIterator ()
 Check all methods of SALOMEDS_SComponentIterator Use code of SALOMEDS_SComponentIterator.cxx. More...
void testSObject ()
 Check all methods of SALOMEDS_SObject Use code of SALOMEDS_SObject.cxx. More...
void testStudy ()
 Check all methods of SALOMEDS_Study Use code of SALOMEDS_Study.cxx. More...
void testStudyBuilder ()
 Check all methods of SALOMEDS_StudyBuilder Use code of SALOMEDS_StudyBuilder.cxx. More...
void testUseCase ()
SALOMEDS::Study_var _study
CORBA::ORB_var _orb
 CPPUNIT_TEST_SUITE (SALOMEDSTest_Embedded)
 CPPUNIT_TEST (testAttributeComment)
 CPPUNIT_TEST (testAttributeDrawable)
 CPPUNIT_TEST (testAttributeExpandable)
 CPPUNIT_TEST (testAttributeExternalFileDef)
 CPPUNIT_TEST (testAttributeFileType)
 CPPUNIT_TEST (testAttributeFlags)
 CPPUNIT_TEST (testAttributeGraphic)
 CPPUNIT_TEST (testAttributeIOR)
 CPPUNIT_TEST (testAttributeInteger)
 CPPUNIT_TEST (testAttributeLocalID)
 CPPUNIT_TEST (testAttributeName)
 CPPUNIT_TEST (testAttributeOpened)
 CPPUNIT_TEST (testAttributeParameter)
 CPPUNIT_TEST (testAttributePersistentRef)
 CPPUNIT_TEST (testAttributePixMap)
 CPPUNIT_TEST (testAttributePythonObject)
 CPPUNIT_TEST (testAttributeReal)
 CPPUNIT_TEST (testAttributeSelectable)
 CPPUNIT_TEST (testAttributeSequenceOfInteger)
 CPPUNIT_TEST (testAttributeSequenceOfReal)
 CPPUNIT_TEST (testAttributeStudyProperties)
 CPPUNIT_TEST (testAttributeTableOfInteger)
 CPPUNIT_TEST (testAttributeTableOfReal)
 CPPUNIT_TEST (testAttributeTableOfString)
 CPPUNIT_TEST (testAttributeTarget)
 CPPUNIT_TEST (testAttributeTextColor)
 CPPUNIT_TEST (testAttributeTextHighlightColor)
 CPPUNIT_TEST (testAttributeTreeNode)
 CPPUNIT_TEST (testAttributeUserID)
 CPPUNIT_TEST (testChildIterator)
 CPPUNIT_TEST (testSComponent)
 CPPUNIT_TEST (testSComponentIterator)
 CPPUNIT_TEST (testSObject)
 CPPUNIT_TEST (testStudy)
 CPPUNIT_TEST (testStudyBuilder)
 CPPUNIT_TEST (testUseCase)
 CPPUNIT_TEST_SUITE_END ()
◆ CPPUNIT_TEST() [1/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeComment  )
◆ CPPUNIT_TEST() [2/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeDrawable  )
◆ CPPUNIT_TEST() [3/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeExpandable  )
◆ CPPUNIT_TEST() [4/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeExternalFileDef  )
◆ CPPUNIT_TEST() [5/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeFileType  )
◆ CPPUNIT_TEST() [6/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeFlags  )
◆ CPPUNIT_TEST() [7/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeGraphic  )
◆ CPPUNIT_TEST() [8/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeInteger  )
◆ CPPUNIT_TEST() [9/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeIOR  )
◆ CPPUNIT_TEST() [10/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeLocalID  )
◆ CPPUNIT_TEST() [11/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeName  )
◆ CPPUNIT_TEST() [12/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeOpened  )
◆ CPPUNIT_TEST() [13/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeParameter  )
◆ CPPUNIT_TEST() [14/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributePersistentRef  )
◆ CPPUNIT_TEST() [15/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributePixMap  )
◆ CPPUNIT_TEST() [16/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributePythonObject  )
◆ CPPUNIT_TEST() [17/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeReal  )
◆ CPPUNIT_TEST() [18/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeSelectable  )
◆ CPPUNIT_TEST() [19/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeSequenceOfInteger  )
◆ CPPUNIT_TEST() [20/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeSequenceOfReal  )
◆ CPPUNIT_TEST() [21/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeStudyProperties  )
◆ CPPUNIT_TEST() [22/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTableOfInteger  )
◆ CPPUNIT_TEST() [23/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTableOfReal  )
◆ CPPUNIT_TEST() [24/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTableOfString  )
◆ CPPUNIT_TEST() [25/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTarget  )
◆ CPPUNIT_TEST() [26/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTextColor  )
◆ CPPUNIT_TEST() [27/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTextHighlightColor  )
◆ CPPUNIT_TEST() [28/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeTreeNode  )
◆ CPPUNIT_TEST() [29/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testAttributeUserID  )
◆ CPPUNIT_TEST() [30/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testChildIterator  )
◆ CPPUNIT_TEST() [31/37]
◆ CPPUNIT_TEST() [32/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testSComponent  )
◆ CPPUNIT_TEST() [33/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testSComponentIterator  )
◆ CPPUNIT_TEST() [34/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testSObject  )
◆ CPPUNIT_TEST() [35/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testStudy  )
◆ CPPUNIT_TEST() [36/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testStudyBuilder  )
◆ CPPUNIT_TEST() [37/37]
SALOMEDSTest_Embedded::CPPUNIT_TEST ( testUseCase  )
◆ CPPUNIT_TEST_SUITE()
SALOMEDSTest_Embedded::CPPUNIT_TEST_SUITE ( SALOMEDSTest_Embedded  )
◆ CPPUNIT_TEST_SUITE_END()
SALOMEDSTest_Embedded::CPPUNIT_TEST_SUITE_END ( )
◆ setUp()
void SALOMEDSTest_Embedded::setUp ( )
◆ tearDown()
void SALOMEDSTest::tearDown ( )
  • delete trace classes
References _PTR, and SALOMEDSTest::_study.
◆ testAttributeComment()
void SALOMEDSTest::testAttributeComment ( )
◆ testAttributeDrawable()
void SALOMEDSTest::testAttributeDrawable ( )
◆ testAttributeExpandable()
void SALOMEDSTest::testAttributeExpandable ( )
◆ testAttributeExternalFileDef()
void SALOMEDSTest::testAttributeExternalFileDef ( )
◆ testAttributeFileType()
void SALOMEDSTest::testAttributeFileType ( )
◆ testAttributeFlags()
void SALOMEDSTest::testAttributeFlags ( )
References _PTR, SALOMEDSTest::_study, and salome::flags.
◆ testAttributeGraphic()
void SALOMEDSTest::testAttributeGraphic ( )
◆ testAttributeInteger()
void SALOMEDSTest::testAttributeInteger ( )
◆ testAttributeIOR()
void SALOMEDSTest::testAttributeIOR ( )
◆ testAttributeLocalID()
void SALOMEDSTest::testAttributeLocalID ( )
◆ testAttributeName()
void SALOMEDSTest::testAttributeName ( )
◆ testAttributeOpened()
void SALOMEDSTest::testAttributeOpened ( )
◆ testAttributeParameter()
void SALOMEDSTest::testAttributeParameter ( )
◆ testAttributePersistentRef()
void SALOMEDSTest::testAttributePersistentRef ( )
◆ testAttributePixMap()
void SALOMEDSTest::testAttributePixMap ( )
◆ testAttributePythonObject()
void SALOMEDSTest::testAttributePythonObject ( )
◆ testAttributeReal()
void SALOMEDSTest::testAttributeReal ( )
◆ testAttributeSelectable()
void SALOMEDSTest::testAttributeSelectable ( )
◆ testAttributeSequenceOfInteger()
void SALOMEDSTest::testAttributeSequenceOfInteger ( )
◆ testAttributeSequenceOfReal()
void SALOMEDSTest::testAttributeSequenceOfReal ( )
◆ testAttributeStudyProperties()
void SALOMEDSTest::testAttributeStudyProperties ( )
◆ testAttributeTableOfInteger()
void SALOMEDSTest::testAttributeTableOfInteger ( )
◆ testAttributeTableOfReal()
void SALOMEDSTest::testAttributeTableOfReal ( )
◆ testAttributeTableOfString()
void SALOMEDSTest::testAttributeTableOfString ( )
◆ testAttributeTarget()
void SALOMEDSTest::testAttributeTarget ( )
◆ testAttributeTextColor()
void SALOMEDSTest::testAttributeTextColor ( )
◆ testAttributeTextHighlightColor()
void SALOMEDSTest::testAttributeTextHighlightColor ( )
◆ testAttributeTreeNode()
void SALOMEDSTest::testAttributeTreeNode ( )
◆ testAttributeUserID()
void SALOMEDSTest::testAttributeUserID ( )
◆ testChildIterator()
void SALOMEDSTest::testChildIterator ( )
◆ testSComponent()
void SALOMEDSTest::testSComponent ( )
References SALOMEDSTest::_orb, _PTR, and SALOMEDSTest::_study.
◆ testSComponentIterator()
void SALOMEDSTest::testSComponentIterator ( )
◆ testSObject()
void SALOMEDSTest::testSObject ( )
◆ testStudy()
void SALOMEDSTest::testStudy ( )
◆ testStudyBuilder()
void SALOMEDSTest::testStudyBuilder ( )
◆ testUseCase()
void SALOMEDSTest::testUseCase ( )
◆ _orb
◆ _study
SALOMEDS::Study_var SALOMEDSTest::_study
