TestSSLAttached Namespace Reference
Variables
 rp
 cp
 cm = salome.naming_service.Resolve("/ContainerManager")
 cont_prov = cm.GiveContainer(cp)
 orb = CORBA.ORB_init([''])
 ref_cm = orb.object_to_string(salome.cm)
 pyscript = cont_prov.createPyScriptNode("testCM",)
 cm_to_test = orb.object_to_string(pickle.loads(pyscript.execute(["the_cm"],pickle.dumps(([],{}))))[0])
 pyscriptt = cont_prov.createPyScriptNode("testCM2",)
 cm_to_testt = orb.object_to_string(pickle.loads(pyscriptt.execute(["the_cm"],pickle.dumps(([],{}))))[0])
 ref_rm = orb.object_to_string(salome.lcc.getResourcesManager())
 pyscript4 = cont_prov.createPyScriptNode("testRM",)
 rm_to_test = orb.object_to_string(pickle.loads(pyscript4.execute(["the_rm"],pickle.dumps(([],{}))))[0])
 pyscript44 = cont_prov.createPyScriptNode("testRM2",)
 rm_to_testt = orb.object_to_string(pickle.loads(pyscript44.execute(["the_rm"],pickle.dumps(([],{}))))[0])
 ref_dsm = orb.object_to_string(salome.dsm)
 pyscript2 = cont_prov.createPyScriptNode("testDSM",)
 dsm_to_test = orb.object_to_string(pickle.loads(pyscript2.execute(["the_dsm"],pickle.dumps(([],{}))))[0])
 pyscript22 = cont_prov.createPyScriptNode("testDSM",)
 dsm_to_test_2 = orb.object_to_string(pickle.loads(pyscript22.execute(["the_dsm"],pickle.dumps(([],{}))))[0])
 ref_esm = orb.object_to_string(salome.esm)
 pyscript3 = cont_prov.createPyScriptNode("testESM",)
 esm_to_test = orb.object_to_string(pickle.loads(pyscript3.execute(["the_esm"],pickle.dumps(([],{}))))[0])
 pyscript33 = cont_prov.createPyScriptNode("testDSM",)
 esm_to_test_2 = orb.object_to_string(pickle.loads(pyscript33.execute(["the_esm"],pickle.dumps(([],{}))))[0])
Variable Documentation
◆ cm
TestSSLAttached.cm = salome.naming_service.Resolve("/ContainerManager")
◆ cm_to_test
TestSSLAttached.cm_to_test = orb.object_to_string(pickle.loads(pyscript.execute(["the_cm"],pickle.dumps(([],{}))))[0])
◆ cm_to_testt
TestSSLAttached.cm_to_testt = orb.object_to_string(pickle.loads(pyscriptt.execute(["the_cm"],pickle.dumps(([],{}))))[0])
◆ cont_prov
TestSSLAttached.cont_prov = cm.GiveContainer(cp)
◆ cp
TestSSLAttached.cp
Initial value:
1= Engines.ContainerParameters(container_name="container_test",
2 mode="start",
3 workingdir=os.getcwd(),
4 nb_proc=1,
5 isMPI=False,
6 parallelLib="",
7 resource_params=rp)
Type to describe required properties of a container.
Definition: SALOME_ContainerManager.idl:38
Referenced by SALOMEDSTest.testStudy().
◆ dsm_to_test
TestSSLAttached.dsm_to_test = orb.object_to_string(pickle.loads(pyscript2.execute(["the_dsm"],pickle.dumps(([],{}))))[0])
◆ dsm_to_test_2
TestSSLAttached.dsm_to_test_2 = orb.object_to_string(pickle.loads(pyscript22.execute(["the_dsm"],pickle.dumps(([],{}))))[0])
◆ esm_to_test
TestSSLAttached.esm_to_test = orb.object_to_string(pickle.loads(pyscript3.execute(["the_esm"],pickle.dumps(([],{}))))[0])
◆ esm_to_test_2
TestSSLAttached.esm_to_test_2 = orb.object_to_string(pickle.loads(pyscript33.execute(["the_esm"],pickle.dumps(([],{}))))[0])
◆ orb
TestSSLAttached.orb = CORBA.ORB_init([''])
◆ pyscript
TestSSLAttached.pyscript = cont_prov.createPyScriptNode("testCM",)
◆ pyscript2
TestSSLAttached.pyscript2 = cont_prov.createPyScriptNode("testDSM",)
◆ pyscript22
TestSSLAttached.pyscript22 = cont_prov.createPyScriptNode("testDSM",)
◆ pyscript3
TestSSLAttached.pyscript3 = cont_prov.createPyScriptNode("testESM",)
◆ pyscript33
TestSSLAttached.pyscript33 = cont_prov.createPyScriptNode("testDSM",)
◆ pyscript4
TestSSLAttached.pyscript4 = cont_prov.createPyScriptNode("testRM",)
◆ pyscript44
TestSSLAttached.pyscript44 = cont_prov.createPyScriptNode("testRM2",)
◆ pyscriptt
TestSSLAttached.pyscriptt = cont_prov.createPyScriptNode("testCM2",)
◆ ref_cm
TestSSLAttached.ref_cm = orb.object_to_string(salome.cm)
◆ ref_dsm
TestSSLAttached.ref_dsm = orb.object_to_string(salome.dsm)
◆ ref_esm
TestSSLAttached.ref_esm = orb.object_to_string(salome.esm)
◆ ref_rm
TestSSLAttached.ref_rm = orb.object_to_string(salome.lcc.getResourcesManager())
◆ rm_to_test
TestSSLAttached.rm_to_test = orb.object_to_string(pickle.loads(pyscript4.execute(["the_rm"],pickle.dumps(([],{}))))[0])
◆ rm_to_testt
TestSSLAttached.rm_to_testt = orb.object_to_string(pickle.loads(pyscript44.execute(["the_rm"],pickle.dumps(([],{}))))[0])
◆ rp
TestSSLAttached.rp
Initial value:
1= Engines.ResourceParameters(name="localhost",
2 hostname="localhost",
3 can_launch_batch_jobs=False,
4 can_run_containers=True,
5 OS="Linux",
6 componentList=[],
7 nb_proc=1,
8 mem_mb=1000,
9 cpu_clock=1000,
10 nb_node=1,
11 nb_proc_per_node=1,
12 policy="first",
13 resList=[])
Type to describe required properties of a resource.
Definition: SALOME_ResourcesManager.idl:42
