SALOMETraceCollector Class Reference
#include <SALOMETraceCollector.hxx>
Inheritance diagram for SALOMETraceCollector:
 ~SALOMETraceCollector ()
 Destructor: wait until printing thread ends (SALOMETraceCollector::run) More...
static BaseTraceCollector * instance ()
 This class is for use with CORBA, inside SALOME. More...
static void * run (void *bid)
 In a separate thread, loop to print traces. More...
 Constructor: no need of LocalTraceBufferPool object initialization here, thread safe singleton used in LocalTraceBufferPool::instance() More...
◆ ~SALOMETraceCollector()
SALOMETraceCollector::~SALOMETraceCollector ( )
References DEVTRACE, and TestKernelHelpers::ret.
◆ SALOMETraceCollector()
SALOMETraceCollector::SALOMETraceCollector ( )
Referenced by instance().
◆ instance()
BaseTraceCollector * SALOMETraceCollector::instance ( )
Type of trace (and corresponding class) is chosen in LocalTraceBufferPool.
Guarantees a unique object instance of the class (singleton thread safe) a separate thread for loop to print traces is launched.
References run(), and SALOMETraceCollector().
Referenced by SingletonInstance(), and TestLauncherSimple.TestLauncher::tearDown().
◆ run()
void * SALOMETraceCollector::run ( void *  bid)
Mutex guarantees initialisation on instance method is done and only one run allowed (double check ...) Loop until there is no more buffer to print, and no ask for end from destructor. Get a buffer. If type = ABORT then exit application with message.
References DEVTRACE, testPerfLogManager1::flush(), KERNEL_PY.batchmode_salome::obj, and TraceCollector_WaitForServerReadiness().
