See also other derived Classes in SALOMELocalTrace for usage without CORBA, see also derived Classes in SALOMETraceCollector for usage with CORBA. More...
#include <FileTraceCollector.hxx>
~FileTraceCollector () | |
Destructor: wait until printing thread ends (FileTraceCollector::run) More... | |
static BaseTraceCollector * | instance (const char *fileName) |
This class is for use without CORBA, inside or outside SALOME. More... | |
static void * | run (void *bid) |
In a separate thread, loop to print traces. More... | |
Constructor: no need of LocalTraceBufferPool object initialization here, thread safe singleton used in LocalTraceBufferPool::instance() More... | |
Static Protected Attributes | |
static std::string | _fileName = "" |
static int | _threadToClose = 0 |
static BaseTraceCollector * | _singleton = 0 |
static pthread_mutex_t | _singletonMutex |
static pthread_t * | _threadId = 0 |
static sem_t | _sem |
FileTraceCollector::~FileTraceCollector | ( | ) |
References BaseTraceCollector::_singleton, BaseTraceCollector::_singletonMutex, BaseTraceCollector::_threadId, BaseTraceCollector::_threadToClose, DEVTRACE, LocalTraceBufferPool::insert(), LocalTraceBufferPool::instance(), NORMAL_MESS, and TestKernelHelpers::ret.
protected |
References BaseTraceCollector::_threadId, and BaseTraceCollector::_threadToClose.
Referenced by instance().
static |
SALOME uses SALOMETraceCollector, to allow trace collection via CORBA. Type of trace (and corresponding class) is chosen in LocalTraceBufferPool.
Guarantees a unique object instance of the class (singleton thread safe) a separate thread for loop to print traces is launched.
References _fileName, BaseTraceCollector::_sem, BaseTraceCollector::_singleton, BaseTraceCollector::_singletonMutex, DEVTRACE, FileTraceCollector(), and run().
Referenced by LocalTraceBufferPool::instance(), and TestLauncherSimple.TestLauncher::tearDown().
static |
Mutex guarantees initialisation on instance method is done and only one run allowed (double check ...) Loop until there is no more buffer to print, and no ask for end from destructor. Get a buffer. If type = ABORT then exit application with message.
References _fileName, BaseTraceCollector::_sem, BaseTraceCollector::_threadId, BaseTraceCollector::_threadToClose, ABORT_MESS, DEVTRACE, LocalTraceBufferPool::instance(), out, LocalTraceBufferPool::retrieve(), LocalTrace_TraceInfo::threadId, LocalTraceBufferPool::toCollect(), LocalTrace_TraceInfo::trace, traceFile, and LocalTrace_TraceInfo::traceType.
staticprotected |
Referenced by instance(), and run().
staticprotectedinherited |
Referenced by FileTraceCollector(), LocalTraceCollector::LocalTraceCollector(), run(), LocalTraceCollector::run(), SALOMETraceCollector::run(), SALOMETraceCollector::SALOMETraceCollector(), ~FileTraceCollector(), LocalTraceCollector::~LocalTraceCollector(), and SALOMETraceCollector::~SALOMETraceCollector().
