HDFtypes.h File Reference
#include <hdf5.h>
Include dependency graph for HDFtypes.h:
#define HDF_NAME_MAX_LEN   100
Typedefs
typedef size_t hdf_size_type
typedef H5T_class_t hdf_class_type
typedef hsize_t hdf_size
typedef hid_t hdf_idt
typedef herr_t hdf_err
typedef hbool_t hdf_bool
typedef H5T_order_t hdf_byte_order
typedef char hdf_char
typedef int hdf_int32
typedef long hdf_int64
typedef double hdf_float64
Enumerations
enum  hdf_access_mode { HDF_RDONLY , HDF_RDWR }
enum  hdf_type {
  HDF_NONE , HDF_STRING , HDF_INT32 , HDF_INT64 ,
  HDF_FLOAT64 , HDF_CHAR , HDF_ARRAY
enum  hdf_object_type {
  HDF_OBJECT , HDF_FILE , HDF_GROUP , HDF_DATASET ,
  HDF_ATTRIBUTE , HDF_ARRAY_TYPE
◆ HDF_NAME_MAX_LEN
Typedef Documentation
◆ hdf_bool
◆ hdf_byte_order
◆ hdf_char
◆ hdf_class_type
◆ hdf_err
◆ hdf_float64
◆ hdf_idt
◆ hdf_int32
◆ hdf_int64
◆ hdf_size
◆ hdf_size_type
◆ hdf_access_mode
HDF_RDONLY
HDF_RDWR
◆ hdf_object_type
HDF_OBJECT
HDF_FILE
HDF_GROUP
HDF_DATASET
HDF_ATTRIBUTE
HDF_ARRAY_TYPE
◆ hdf_type
enum hdf_type
HDF_NONE
HDF_STRING
HDF_INT32
HDF_INT64
HDF_FLOAT64
HDF_CHAR
HDF_ARRAY
