HDFtypes.h
1/* Copyright (C) 2007-2026 CEA, EDF, OPEN CASCADE
2 *
3 * Copyright (C) 2003-2007 OPEN CASCADE, EADS/CCR, LIP6, CEA/DEN,
4 * CEDRAT, EDF R&D, LEG, PRINCIPIA R&D, BUREAU VERITAS
5 *
6 * This library is free software; you can redistribute it and/or
7 * modify it under the terms of the GNU Lesser General Public
8 * License as published by the Free Software Foundation; either
9 * version 2.1 of the License, or (at your option) any later version.
10 *
11 * This library is distributed in the hope that it will be useful,
12 * but WITHOUT ANY WARRANTY; without even the implied warranty of
13 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
14 * Lesser General Public License for more details.
15 *
16 * You should have received a copy of the GNU Lesser General Public
17 * License along with this library; if not, write to the Free Software
18 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
19 *
20 * See http://www.salome-platform.org/ or email : webmaster.salome@opencascade.com
21 */
23/*----------------------------------------------------------------------------------
24 SALOME HDFPersist : implementation of HDF persitent ( save/ restore )
25 File : HDFtypes.h
26 Module : SALOME
27----------------------------------------------------------------------------------*/
28
29#ifndef HDFTYPES_H
30#define HDFTYPES_H
31
32#include <hdf5.h>
33
34/* max length of a HDF object */
35#define HDF_NAME_MAX_LEN 100
36
37/* HDF 5 types */
38typedef size_t hdf_size_type;
39typedef H5T_class_t hdf_class_type;
40typedef hsize_t hdf_size;
41typedef hid_t hdf_idt;
42typedef herr_t hdf_err;
43typedef hbool_t hdf_bool;
44typedef H5T_order_t hdf_byte_order;
45
46typedef char hdf_char;
47typedef int hdf_int32;
48typedef long hdf_int64;
49typedef double hdf_float64;
50
51/* Access Mode */
53
54/* Values types for HDF datasets and attributes */
56/* - HDF_STRING : C string
57 - HDF_INT32 : 32 bits integer
58 - HDF_INT64 : 64 bits integer
59 - HDF_FLOAT64 : IEEE 64 bits float
60 - HDF_ARRAY : Array
61*/
62
63/* HDF object types */
66
67#endif /* HDFTYPES_H */
long hdf_int64
Definition: HDFtypes.h:48
hbool_t hdf_bool
Definition: HDFtypes.h:43
herr_t hdf_err
Definition: HDFtypes.h:42
Definition: HDFtypes.h:39
hdf_access_mode
Definition: HDFtypes.h:52
@ HDF_RDWR
@ HDF_RDONLY
hid_t hdf_idt
Definition: HDFtypes.h:41
int hdf_int32
Definition: HDFtypes.h:47
hdf_object_type
Definition: HDFtypes.h:64
@ HDF_ATTRIBUTE
Definition: HDFtypes.h:65
@ HDF_OBJECT
@ HDF_ARRAY_TYPE
@ HDF_FILE
@ HDF_DATASET
@ HDF_GROUP
hdf_type
Definition: HDFtypes.h:55
@ HDF_INT32
@ HDF_INT64
@ HDF_STRING
@ HDF_ARRAY
@ HDF_FLOAT64
@ HDF_CHAR
@ HDF_NONE
char hdf_char
Definition: HDFtypes.h:46
Definition: HDFtypes.h:38
double hdf_float64
Definition: HDFtypes.h:49
hsize_t hdf_size
Definition: HDFtypes.h:40
Definition: HDFtypes.h:44
