provides_port Class Referenceabstract
This class implements a DSC_User provides C++ port. More...
#include <provides_port.hxx>
Inheritance diagram for provides_port:
 provides_port ()
virtual ~provides_port ()
virtual Ports::Port_ptr get_port_ref ()=0
 This method permits to get the CORBA reference of the port. More...
virtual void provides_port_changed (int, const Engines::DSC::Message)
 This method is the callback called by the component to inform the provides port of a new or a removed connection. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
PortProperties_i * default_properties
This class is base class for all DSC_User provides port. It's an abstract class.
◆ provides_port()
provides_port::provides_port ( )
◆ ~provides_port()
provides_port::~provides_port ( )
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_port_ref()
virtual Ports::Port_ptr provides_port::get_port_ref ( )
pure virtual
port's CORBA reference.
Implemented in data_short_port_provides, palm_data_seq_short_port_provides, and palm_data_short_port_provides.
◆ provides_port_changed()
virtual void provides_port::provides_port_changed ( int  ,
connection_nbrcurrent connection number.
messagemessage associated with this connection.
◆ default_properties
PortProperties_i* base_port::default_properties
