provides_port.hxx
23// File : provides_port.hxx
24// Author : André RIBES (EDF)
25// Module : KERNEL
26//
27#ifndef _PROVIDES_PORT_HXX_
28#define _PROVIDES_PORT_HXX_
30#include "base_port.hxx"
31#include "SALOME_Ports.hh"
32#include "DSC_Engines.hh"
33
41{
42 public :
44 virtual ~provides_port();
45
51 virtual Ports::Port_ptr get_port_ref() = 0;
52
60 virtual void provides_port_changed(int /*connection_nbr*/,
61 const Engines::DSC::Message /*message*/) {}
62
63};
64
65#endif
66
Definition: base_port.hxx:36
This class implements a DSC_User provides C++ port.
Definition: provides_port.hxx:41
provides_port()
Definition: provides_port.cxx:29
virtual void provides_port_changed(int, const Engines::DSC::Message)
This method is the callback called by the component to inform the provides port of a new or a removed...
Definition: provides_port.hxx:60
Definition: provides_port.cxx:32
virtual Ports::Port_ptr get_port_ref()=0
This method permits to get the CORBA reference of the port.
Message
This enumeration is used when the connection of a port (uses or provides) is changed.
Definition: DSC_Engines.idl:79
