data_short_port_provides Class Reference
This class a port that sends a CORBA short with the basic port policy. More...
#include <data_short_port_provides.hxx>
Inheritance diagram for data_short_port_provides:
 data_short_port_provides ()
virtual ~data_short_port_provides ()
virtual void put (CORBA::Short data)
 This method implements the CORBA method of the interface. More...
virtual CORBA::Short get ()
 This method is used by the component to get the last value received. More...
virtual Ports::Port_ptr get_port_ref ()
 This method gives the port CORBA reference. More...
virtual void provides_port_changed (int, const Engines::DSC::Message)
 This method is the callback called by the component to inform the provides port of a new or a removed connection. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
PortProperties_i * default_properties
CORBA::Short _val
pthread_mutex_t * short_mutex
pthread_cond_t * short_condition
bool short_termine
pthread_mutex_t * short_mutex_cp
pthread_cond_t * short_condition_cp
bool short_termine_cp
◆ data_short_port_provides()
data_short_port_provides::data_short_port_provides ( )
◆ ~data_short_port_provides()
data_short_port_provides::~data_short_port_provides ( )
◆ get()
CORBA::Short data_short_port_provides::get ( )
the last value received (default 0).
References _val, short_condition, short_condition_cp, short_mutex, short_mutex_cp, short_termine, and short_termine_cp.
Referenced by SALOME_PyNode.BigObjectOnDiskBase::__float__(), SALOME_PyNode.BigObjectOnDiskListElement::__getitem__(), SALOME_PyNode.BigObjectOnDiskBase::__int__(), SALOME_PyNode.BigObjectOnDiskListElement::__len__(), SALOME_PyNode.BigObjectOnDiskBase::__str__(), KERNEL_PY.salome_notebook.NoteBook::check(), SALOME_ContainerHelper.ScriptInfoDeco::code(), SALOME_ContainerHelper.ScriptExecInfoDeco::CPUMemDuringExec(), SALOME_ContainerHelper.ScriptExecInfoDeco::endExecTime(), SALOME_ContainerHelper.ScriptExecInfoDeco::endInputTime(), SALOME_ContainerHelper.ScriptExecInfoDeco::endOutputTime(), SALOME_ContainerHelper.ScriptExecInfoDeco::execTime(), SALOME_ContainerHelper.ScriptExecInfoDeco::freestyle(), SALOME_ContainerHelper.ScriptExecInfoDeco::fullExecTime(), KERNEL_PY.salome_notebook.NoteBook::get(), SALOME_ContainerHelper.ScriptExecInfoDeco::inputHDDMem(), SALOME_ContainerHelper.ScriptExecInfoDeco::inputMem(), SALOME_ContainerHelper.ScriptExecInfoDeco::inputReadHDDSize(), SALOME_ContainerHelper.ScriptExecInfoDeco::inputReadHDDSizeRepr(), SALOME_ContainerHelper.ScriptExecInfoDeco::inputReadHDDSpeed(), SALOME_ContainerHelper.ScriptExecInfoDeco::inputReadHDDSpeedRepr(), SALOME_ContainerHelper.ScriptExecInfoDeco::measureTimeResolution(), SALOME_ContainerHelper.ScriptInfoDeco::nodeName(), SALOME_ContainerHelper.ScriptExecInfoDeco::outputHDDMem(), SALOME_ContainerHelper.ScriptExecInfoDeco::outputMem(), SALOME_ContainerHelper.ScriptExecInfoDeco::outputWriteHDDSize(), SALOME_ContainerHelper.ScriptExecInfoDeco::outputWriteHDDSizeRepr(), SALOME_ContainerHelper.ScriptExecInfoDeco::outputWriteHDDSpeed(), SALOME_ContainerHelper.ScriptExecInfoDeco::outputWriteHDDSpeedRepr(), KERNEL_PY.salome_notebook.NoteBook::setAs(), SALOME_ContainerHelper.ScriptExecInfoDeco::startExecTime(), SALOME_ContainerHelper.ScriptExecInfoDeco::startInputTime(), and SALOME_ContainerHelper.ScriptExecInfoDeco::startOutputTime().
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_port_ref()
Ports::Port_ptr data_short_port_provides::get_port_ref ( )
port's CORBA reference.
Implements provides_port.
◆ provides_port_changed()
virtual void provides_port::provides_port_changed ( int  ,
connection_nbrcurrent connection number.
messagemessage associated with this connection.
◆ put()
void data_short_port_provides::put ( CORBA::Short  data)
See also
Ports::Data_Short_Port::put
◆ _val
CORBA::Short data_short_port_provides::_val
Referenced by data_short_port_provides(), get(), and put().
◆ default_properties
PortProperties_i* base_port::default_properties
◆ short_condition
pthread_cond_t* data_short_port_provides::short_condition
◆ short_condition_cp
pthread_cond_t* data_short_port_provides::short_condition_cp
◆ short_mutex
pthread_mutex_t* data_short_port_provides::short_mutex
◆ short_mutex_cp
pthread_mutex_t* data_short_port_provides::short_mutex_cp
◆ short_termine
bool data_short_port_provides::short_termine
◆ short_termine_cp
bool data_short_port_provides::short_termine_cp
