palm_data_seq_short_port_provides Class Reference
#include <palm_data_seq_short_port_provides.hxx>
Inheritance diagram for palm_data_seq_short_port_provides:
typedef DataManipulator::Type DataType
typedef DataManipulator::CorbaInType CorbaInDataType
typedef CORBA::Long TimeType
typedef CORBA::Long TagType
typedef InternalDataIdContainer< TimeType, TagType > DataIdContainer
 palm_data_seq_short_port_provides ()
virtual ~palm_data_seq_short_port_provides ()
void put (DataManipulator::CorbaInType data, CORBA::Long time, CORBA::Long tag)
Ports::Port_ptr get_port_ref ()
 This method permits to get the CORBA reference of the port. More...
virtual void provides_port_changed (int, const Engines::DSC::Message)
 This method is the callback called by the component to inform the provides port of a new or a removed connection. More...
virtual Ports::PortProperties_ptr get_port_properties ()
 This is used to get the property object of the port. More...
void put (CorbaInDataType data, TimeType time, TagType tag)
DataType get (TimeType time, TagType tag)
DataType get (TimeType &ti, TimeType tf, TagType tag=0)
DataManipulator::Type get (TimeType time, TagType tag)
DataManipulator::Type get (TimeType &ti, TimeType tf, TagType tag)
DataType next (TimeType &t, TagType &tag)
DataManipulator::Type next (TimeType &t, TagType &tag)
void close (PortableServer::POA_var poa, PortableServer::ObjectId_var id)
void wakeupWaiting ()
void erase (TimeType time, TagType tag, bool before)
filtre_conversion * get_filtre_convert_TIME ()
filtre_conversion * get_filtre_convert_TAG ()
TimeType getTime (const DataId &dataId) const
TagType getTag (const DataId &dataId) const
template<typename Container >
bool isDataIdConveniant (Container &storedDatas, const typename Container::key_type &expectedDataId, bool &isEqual, bool &isBounded, typename Container::iterator &wDataIt1) const
PortProperties_i * default_properties
Private Types
typedef Ports::Palm_Ports::seq_short CorbaDataType
typedef seq_u_manipulation< CorbaDataType, CORBA::Short > DataManipulator
typedef GenericPort< DataManipulator, PalmCouplingPolicy > Port
typedef COUPLING_POLICY::DataId DataId
typedef std::map< DataId, DataType > DataTable
DataTable storedDatas
bool waitingForConvenientDataId
bool waitingForAnyDataId
DataId expectedDataId
DataId lastDataId
bool lastDataIdSet
omni_mutex storedDatas_mutex
omni_condition cond_instance
filtre_conversion filtre_convert_TIME
filtre_conversion filtre_convert_TAG
◆ CorbaDataType
◆ CorbaInDataType
◆ DataId
typedef COUPLING_POLICY::DataId GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::DataId
privateinherited
◆ DataIdContainer
◆ DataManipulator
◆ DataTable
typedef std::map< DataId, DataType> GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::DataTable
privateinherited
◆ DataType
◆ Port
◆ TagType
typedef CORBA::Long PalmCouplingPolicy::TagType
◆ TimeType
typedef CORBA::Long PalmCouplingPolicy::TimeType
◆ palm_data_seq_short_port_provides()
palm_data_seq_short_port_provides::palm_data_seq_short_port_provides ( )
◆ ~palm_data_seq_short_port_provides()
virtual palm_data_seq_short_port_provides::~palm_data_seq_short_port_provides ( )
◆ close()
void GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::close ( PortableServer::POA_var  poa,
◆ erase()
void GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::erase ( TimeType  time,
TagType  tag,
bool  before
◆ get() [1/4]
◆ get() [2/4]
DataType GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::get ( TimeType &  ti,
TimeType  tf,
TagType  tag = 0
◆ get() [3/4]
◆ get() [4/4]
◆ get_filtre_convert_TAG()
filtre_conversion * PalmCouplingPolicy::get_filtre_convert_TAG ( )
◆ get_filtre_convert_TIME()
filtre_conversion * PalmCouplingPolicy::get_filtre_convert_TIME ( )
◆ get_port_properties()
Ports::PortProperties_ptr base_port::get_port_properties ( )
property's CORBA reference.
References base_port::default_properties.
◆ get_port_ref()
Ports::Port_ptr palm_data_seq_short_port_provides::get_port_ref ( )
port's CORBA reference.
Implements provides_port.
◆ getTag()
TagType PalmCouplingPolicy::getTag ( const DataId &  dataId) const
◆ getTime()
TimeType PalmCouplingPolicy::getTime ( const DataId &  dataId) const
◆ isDataIdConveniant()
bool CouplingPolicy::isDataIdConveniant ( Container &  storedDatas,
const typename Container::key_type &  expectedDataId,
bool &  isEqual,
bool &  isBounded,
typename Container::iterator &  wDataIt1
◆ next() [1/2]
DataType GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::next ( TimeType &  t,
TagType &  tag
◆ next() [2/2]
◆ provides_port_changed()
virtual void provides_port::provides_port_changed ( int  ,
connection_nbrcurrent connection number.
messagemessage associated with this connection.
◆ put() [1/2]
void GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::put ( CorbaInDataType  data,
TimeType  time,
TagType  tag
◆ put() [2/2]
void palm_data_seq_short_port_provides::put ( DataManipulator::CorbaInType  data,
CORBA::Long  time,
CORBA::Long  tag
◆ wakeupWaiting()
void GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::wakeupWaiting
Reimplemented from CouplingPolicy.
◆ cond_instance
omni_condition GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::cond_instance
privateinherited
◆ default_properties
PortProperties_i* base_port::default_properties
◆ expectedDataId
DataId GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::expectedDataId
privateinherited
◆ filtre_convert_TAG
◆ filtre_convert_TIME
◆ lastDataId
DataId GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::lastDataId
privateinherited
◆ lastDataIdSet
bool GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::lastDataIdSet
privateinherited
◆ storedDatas
DataTable GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::storedDatas
privateinherited
◆ storedDatas_mutex
omni_mutex GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::storedDatas_mutex
privateinherited
◆ waitingForAnyDataId
bool GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::waitingForAnyDataId
privateinherited
◆ waitingForConvenientDataId
bool GenericPort< seq_u_manipulation< Ports::Palm_Ports::seq_short, CORBA::Short > , PalmCouplingPolicy >::waitingForConvenientDataId
privateinherited
