DF_Container.hxx
20#ifndef DFCONTAINER_HXX
21#define DFCONTAINER_HXX
23#include "DF_definitions.hxx"
24#include "DF_Attribute.hxx"
25#include <string>
26#include <map>
27
28//Class DF_Container is used to store several types of data
30{
31public:
32
33 //Static method that returns an ID of the give type of attributes
34 Standard_EXPORT static const std::string& GetID();
35
36 //Creates if not exists a Container attribute and places if is not placed it the Label
37 Standard_EXPORT static DF_Container* Set(DF_Label& theLabel);
38
39 //Constructor
41
42 //Destructor
44
45 //Sets an integer value of the attribute with given ID
46 Standard_EXPORT void SetInt(const std::string& theID, int theValue);
47
48 //Returns an integer value of the attribute with given ID
49 Standard_EXPORT int GetInt(const std::string& theID);
50
51 //Returns True if there is an integer with given ID
52 Standard_EXPORT bool HasIntID(const std::string& theID);
53
54 //Sets a double value of the attribute with given ID
55 Standard_EXPORT void SetDouble(const std::string& theID, const double& theValue);
56
57 //Returns a double value of the attribute with given ID
58 Standard_EXPORT double GetDouble(const std::string& theID);
59
60 //Returns True if there is a double with given ID
61 Standard_EXPORT bool HasDoubleID(const std::string& theID);
62
63 //Sets a string value of the attribute with given ID
64 Standard_EXPORT void SetString(const std::string& theID, const std::string& theValue);
65
66 //Returns a string value of the attribute with given ID
67 Standard_EXPORT std::string GetString(const std::string& theID);
68
69 //Returns True if there is a string with given ID
70 Standard_EXPORT bool HasStringID(const std::string& theID);
71
72 //Sets a boolean value of the attribute with given ID
73 Standard_EXPORT void SetBool(const std::string& theID, bool theValue);
74
75 //Returns a boolean value of the attribute with given ID
76 Standard_EXPORT bool GetBool(const std::string& theID);
77
78 //Returns True if there is a boolean value with given ID
79 Standard_EXPORT bool HasBoolID(const std::string& theID);
80
81 //Clears a content of the attribute
83
84 //ID is a std::string that uniquely identify the given type of Attributes within the Application.
85 Standard_EXPORT virtual const std::string& ID() const;
86
87 //Restores a content of this Attribute from another Attribute
88 Standard_EXPORT virtual void Restore(DF_Attribute* theAttribute);
89
90 //Creates a new empty copy of this Attribute
91 Standard_EXPORT virtual DF_Attribute* NewEmpty() const;
92
93 //Pastes a content of this Attribute into another Attribute
94 Standard_EXPORT virtual void Paste(DF_Attribute* theIntoAttribute);
95
96
97protected:
98 std::map<std::string, int> _ints;
99 std::map<std::string, double> _doubles;
100 std::map<std::string, std::string> _strings;
101 std::map<std::string, bool> _bools;
102};
103
104#endif
#define Standard_EXPORT
Definition: DF_definitions.hxx:53
Definition: DF_Attribute.hxx:30
Definition: DF_Container.hxx:30
bool HasBoolID(const std::string &theID)
Definition: DF_Container.cxx:137
virtual void Restore(DF_Attribute *theAttribute)
Definition: DF_Container.cxx:159
std::map< std::string, double > _doubles
Definition: DF_Container.hxx:99
virtual DF_Attribute * NewEmpty() const
Definition: DF_Container.cxx:184
DF_Container()
Definition: DF_Container.cxx:44
int GetInt(const std::string &theID)
Definition: DF_Container.cxx:68
bool HasStringID(const std::string &theID)
Definition: DF_Container.cxx:117
static DF_Container * Set(DF_Label &theLabel)
Definition: DF_Container.cxx:32
std::map< std::string, std::string > _strings
Definition: DF_Container.hxx:100
void SetBool(const std::string &theID, bool theValue)
Definition: DF_Container.cxx:124
bool HasIntID(const std::string &theID)
Definition: DF_Container.cxx:76
void SetString(const std::string &theID, const std::string &theValue)
Definition: DF_Container.cxx:104
bool HasDoubleID(const std::string &theID)
Definition: DF_Container.cxx:97
void SetDouble(const std::string &theID, const double &theValue)
Definition: DF_Container.cxx:83
virtual const std::string & ID() const
Definition: DF_Container.cxx:153
double GetDouble(const std::string &theID)
Definition: DF_Container.cxx:90
void SetInt(const std::string &theID, int theValue)
Definition: DF_Container.cxx:62
std::map< std::string, bool > _bools
Definition: DF_Container.hxx:101
std::string GetString(const std::string &theID)
Definition: DF_Container.cxx:110
bool GetBool(const std::string &theID)
Definition: DF_Container.cxx:130
std::map< std::string, int > _ints
Definition: DF_Container.hxx:98
virtual void Paste(DF_Attribute *theIntoAttribute)
Definition: DF_Container.cxx:190
~DF_Container()
Definition: DF_Container.cxx:53
static const std::string & GetID()
Definition: DF_Container.cxx:25
void Clear()
Definition: DF_Container.cxx:144
Definition: DF_Label.hxx:65
