DF_Container Class Reference
#include <DF_Container.hxx>
Inheritance diagram for DF_Container:
 DF_Container ()
 ~DF_Container ()
void SetInt (const std::string &theID, int theValue)
int GetInt (const std::string &theID)
bool HasIntID (const std::string &theID)
void SetDouble (const std::string &theID, const double &theValue)
double GetDouble (const std::string &theID)
bool HasDoubleID (const std::string &theID)
void SetString (const std::string &theID, const std::string &theValue)
std::string GetString (const std::string &theID)
bool HasStringID (const std::string &theID)
void SetBool (const std::string &theID, bool theValue)
bool GetBool (const std::string &theID)
bool HasBoolID (const std::string &theID)
void Clear ()
virtual const std::string & ID () const
virtual void Restore (DF_Attribute *theAttribute)
virtual DF_Attribute * NewEmpty () const
virtual void Paste (DF_Attribute *theIntoAttribute)
DF_Label Label () const
DF_Attribute * FindAttribute (const std::string &theID) const
virtual std::string Save ()
virtual void Load (const std::string &)
virtual void AfterAddition ()
virtual void BeforeForget ()
static const std::string & GetID ()
static DF_Container * Set (DF_Label &theLabel)
void Backup ()
std::map< std::string, int > _ints
std::map< std::string, double > _doubles
std::map< std::string, std::string > _strings
std::map< std::string, bool > _bools
DF_LabelNode * _node
◆ DF_Container()
DF_Container::DF_Container ( )
References _bools, _doubles, _ints, and _strings.
Referenced by NewEmpty(), and Set().
◆ ~DF_Container()
DF_Container::~DF_Container ( )
◆ AfterAddition()
virtual void DF_Attribute::AfterAddition ( )
Reimplemented in SALOMEDSImpl_AttributeTreeNode.
Referenced by DF_Label::AddAttribute().
◆ Backup()
void DF_Attribute::Backup ( )
Referenced by SALOMEDSImpl_AttributeSequenceOfReal::Add(), SALOMEDSImpl_AttributeSequenceOfInteger::Add(), SALOMEDSImpl_AttributeTarget::Add(), SALOMEDSImpl_AttributeSequenceOfReal::Assign(), SALOMEDSImpl_AttributeSequenceOfInteger::Assign(), SALOMEDSImpl_AttributeTextColor::ChangeArray(), SALOMEDSImpl_AttributeTextHighlightColor::ChangeArray(), SALOMEDSImpl_AttributeStudyProperties::ChangeCreatorName(), SALOMEDSImpl_AttributeSequenceOfReal::ChangeValue(), SALOMEDSImpl_AttributeSequenceOfInteger::ChangeValue(), SALOMEDSImpl_AttributeParameter::Clear(), SALOMEDSImpl_AttributeTableOfInteger::Load(), SALOMEDSImpl_AttributeTableOfReal::Load(), SALOMEDSImpl_AttributeTableOfString::Load(), SALOMEDSImpl_AttributeParameter::Load(), SALOMEDSImpl_AttributeSequenceOfInteger::Remove(), SALOMEDSImpl_AttributeSequenceOfReal::Remove(), SALOMEDSImpl_AttributeTarget::Remove(), SALOMEDSImpl_AttributeParameter::RemoveID(), SALOMEDSImpl_AttributeReference::Set(), SALOMEDSImpl_AttributeFlags::Set(), SALOMEDSImpl_AttributeParameter::SetBool(), SALOMEDSImpl_AttributeTableOfReal::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnData(), SALOMEDSImpl_AttributeTableOfString::SetColumnData(), SALOMEDSImpl_AttributeTableOfInteger::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfReal::SetColumnTitle(), SALOMEDSImpl_AttributeTableOfString::SetColumnTitle(), SALOMEDSImpl_AttributeStudyProperties::SetComment(), SALOMEDSImpl_AttributeStudyProperties::SetComponentVersion(), SALOMEDSImpl_AttributeStudyProperties::SetCreationMode(), SALOMEDSImpl_AttributeDrawable::SetDrawable(), SALOMEDSImpl_AttributeExpandable::SetExpandable(), SALOMEDSImpl_AttributeTreeNode::SetFather(), SALOMEDSImpl_AttributeTreeNode::SetFirst(), SALOMEDSImpl_AttributeParameter::SetInt(), SALOMEDSImpl_AttributeParameter::SetIntArray(), SALOMEDSImpl_AttributeStudyProperties::SetModification(), SALOMEDSImpl_AttributeTableOfInteger::SetNbColumns(), SALOMEDSImpl_AttributeTableOfReal::SetNbColumns(), SALOMEDSImpl_AttributeTableOfString::SetNbColumns(), SALOMEDSImpl_AttributeTreeNode::SetNext(), SALOMEDSImpl_AttributePythonObject::SetObject(), SALOMEDSImpl_AttributeOpened::SetOpened(), SALOMEDSImpl_AttributePixMap::SetPixMap(), SALOMEDSImpl_AttributeTreeNode::SetPrevious(), SALOMEDSImpl_AttributeParameter::SetReal(), SALOMEDSImpl_AttributeParameter::SetRealArray(), SALOMEDSImpl_AttributeTarget::SetRelation(), SALOMEDSImpl_AttributeTableOfReal::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowData(), SALOMEDSImpl_AttributeTableOfString::SetRowData(), SALOMEDSImpl_AttributeTableOfInteger::SetRowTitle(), SALOMEDSImpl_AttributeTableOfReal::SetRowTitle(), SALOMEDSImpl_AttributeTableOfString::SetRowTitle(), SALOMEDSImpl_AttributeTableOfInteger::SetRowUnit(), SALOMEDSImpl_AttributeTableOfReal::SetRowUnit(), SALOMEDSImpl_AttributeTableOfString::SetRowUnit(), SALOMEDSImpl_AttributeSelectable::SetSelectable(), SALOMEDSImpl_AttributeParameter::SetStrArray(), SALOMEDSImpl_AttributeParameter::SetString(), SALOMEDSImpl_AttributeTextColor::SetTextColor(), SALOMEDSImpl_AttributeTextHighlightColor::SetTextHighlightColor(), SALOMEDSImpl_AttributeTableOfInteger::SetTitle(), SALOMEDSImpl_AttributeTableOfReal::SetTitle(), SALOMEDSImpl_AttributeTableOfString::SetTitle(), SALOMEDSImpl_AttributeStudyProperties::SetUnits(), SALOMEDSImpl_AttributeReal::SetValue(), SALOMEDSImpl_AttributeInteger::SetValue(), SALOMEDSImpl_AttributeLocalID::SetValue(), SALOMEDSImpl_AttributeComment::SetValue(), SALOMEDSImpl_AttributeString::SetValue(), SALOMEDSImpl_AttributeName::SetValue(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_AttributeExternalFileDef::SetValue(), SALOMEDSImpl_AttributeFileType::SetValue(), SALOMEDSImpl_AttributePersistentRef::SetValue(), SALOMEDSImpl_AttributeUserID::SetValue(), and SALOMEDSImpl_AttributeGraphic::SetVisibility().
◆ BeforeForget()
virtual void DF_Attribute::BeforeForget ( )
◆ Clear()
void DF_Container::Clear ( )
Referenced by Paste(), and Restore().
◆ FindAttribute()
◆ GetBool()
bool DF_Container::GetBool ( const std::string &  theID)
References _bools, and HasBoolID().
◆ GetDouble()
double DF_Container::GetDouble ( const std::string &  theID)
References _doubles, and HasDoubleID().
◆ GetID()
const std::string & DF_Container::GetID ( )
Referenced by ID(), and Set().
◆ GetInt()
int DF_Container::GetInt ( const std::string &  theID)
References _ints, and HasIntID().
◆ GetString()
std::string DF_Container::GetString ( const std::string &  theID)
References _strings, and HasStringID().
◆ HasBoolID()
bool DF_Container::HasBoolID ( const std::string &  theID)
References _bools.
Referenced by GetBool().
◆ HasDoubleID()
bool DF_Container::HasDoubleID ( const std::string &  theID)
References _doubles.
Referenced by GetDouble().
◆ HasIntID()
bool DF_Container::HasIntID ( const std::string &  theID)
References _ints.
Referenced by GetInt().
◆ HasStringID()
bool DF_Container::HasStringID ( const std::string &  theID)
References _strings.
Referenced by GetString().
◆ ID()
const std::string & DF_Container::ID ( ) const
Implements DF_Attribute.
References GetID().
◆ Label()
DF_Label DF_Attribute::Label ( ) const
References DF_Attribute::_node, and DF_Attribute::DF_Label.
Referenced by SALOMEDS_AttributeTarget_i::Add(), SALOMEDSImpl_UseCaseBuilder::Append(), SALOMEDSImpl_AttributeTreeNode::Append(), SALOMEDSImpl_GenericAttribute::CheckLocked(), DF_Attribute::FindAttribute(), SALOMEDSImpl_UseCaseBuilder::GetCurrentObject(), SALOMEDSImpl_AttributeParameter::GetFather(), GetNode(), SALOMEDS_GenericAttribute_i::GetSObject(), SALOMEDSImpl_GenericAttribute::GetSObject(), SALOMEDSImpl_UseCaseBuilder::GetSObject(), SALOMEDSImpl_UseCaseBuilder::HasChildren(), SALOMEDSImpl_AttributeParameter::HasFather(), SALOMEDSImpl_AttributeTreeNode::InsertAfter(), SALOMEDSImpl_AttributeTreeNode::InsertBefore(), SALOMEDSImpl_Study::IORUpdated(), SALOMEDSImpl_UseCaseBuilder::IsUseCaseNode(), SALOMEDS_AttributeTreeNode::Label(), SALOMEDS_AttributeTreeNode_i::Label(), SALOMEDSImpl_AttributeTreeNode::Load(), SALOMEDSImpl_AttributeReference::Load(), SALOMEDSImpl_AttributeTreeNode::Prepend(), SALOMEDSImpl_UseCaseBuilder::Remove(), SALOMEDS_AttributeTarget_i::Remove(), SALOMEDSImpl_UseCaseBuilder::SALOMEDSImpl_UseCaseBuilder(), SALOMEDSImpl_AttributeTreeNode::Save(), SALOMEDSImpl_UseCaseBuilder::SetCurrentObject(), SALOMEDSImpl_GenericAttribute::SetModifyFlag(), SALOMEDSImpl_UseCaseBuilder::SetName(), SALOMEDSImpl_UseCaseBuilder::SetRootCurrent(), SALOMEDSImpl_AttributeIOR::SetValue(), SALOMEDSImpl_UseCaseBuilder::SortChildren(), Translate_persistentID_to_IOR(), SALOMEDSImpl_UseCaseIterator::Value(), and SALOMEDSImpl_AttributeIOR::~SALOMEDSImpl_AttributeIOR().
◆ Load()
◆ NewEmpty()
DF_Attribute * DF_Container::NewEmpty ( ) const
References DF_Container().
◆ Paste()
void DF_Container::Paste ( DF_Attribute *  theIntoAttribute)
References _bools, _doubles, _ints, _strings, and Clear().
◆ Restore()
void DF_Container::Restore ( DF_Attribute *  theAttribute)
◆ Save()
◆ Set()
DF_Container * DF_Container::Set ( DF_Label &  theLabel)
◆ SetBool()
void DF_Container::SetBool ( const std::string &  theID,
bool  theValue
References _bools.
◆ SetDouble()
void DF_Container::SetDouble ( const std::string &  theID,
const double &  theValue
◆ SetInt()
void DF_Container::SetInt ( const std::string &  theID,
int  theValue
References _ints.
◆ SetString()
void DF_Container::SetString ( const std::string &  theID,
const std::string &  theValue
◆ _bools
std::map<std::string, bool> DF_Container::_bools
◆ _doubles
std::map<std::string, double> DF_Container::_doubles
◆ _ints
std::map<std::string, int> DF_Container::_ints
◆ _node
◆ _strings
std::map<std::string, std::string> DF_Container::_strings
